Logicity Schedule
I actually saved the post you put up in the case I need to refer to it at a later date. I am just using ODBC reports with logicity right now.
--- In vantage@yahoogroups.com, Chris Thompson <chriselectrix@...> wrote:
> Thanks.
> Ive managed to get Logicity working beautifully off a BAQ if you are interested.
> From: mmcwilliams22 <mmcwilliams22@...>
> To: vantage@yahoogroups.com
> Sent: Thu, 24 March, 2011 12:47:11
> Subject: [Vantage] Re: Logicity Schedule
> ÂÂ
> Go into the control panel, scheduled tasks. Then open the task and in the
> schedule tab use the advanced button. Make it run every few minutes for 9999
> days.
> --- In vantage@yahoogroups.com, Chris Thompson <chriselectrix@> wrote:
> > Hi All
> > Do you know how I can get Logicity to schedule every 5 or 10 minutes rather
> >than
> > the preset options of Daily (the minimum)?
> > I was thinking of some sort of command line script or something that could be
> > added to a batch file and put on a Windows schedule.
> > Any suggestions would be appreciated.
> > My only option at the minute is to have hundreads of files created and each on
> > set to schedule 5 minutes ahead of the previous one (which will be very tedious
> > to implement).
> > Thanks.
Hi All
Do you know how I can get Logicity to schedule every 5 or 10 minutes rather than
to implement).
Thanks.
Go into the control panel, scheduled tasks. Then open the task and in the schedule tab use the advanced button. Make it run every few minutes for 9999 days.
> Hi All
> to implement).
> Thanks.
Thanks.
Â
days.
> Hi All
>than
> to implement).
> Thanks.
