I have also had login issues where all the client licenses are taken up
and it rejects the passwords during login. You have to go into the V8
Admin tools and under Maintain Sessions and remove unused sessions (or
reboot). This used to happen a lot to us a lot in the beginning of our
V8 install during the turning on and off of the app servers and the
sessions weren't being cleared. Sometimes users got more than one
session and the licenses ran out.
Also, when checking on the apps servers Task Agent, make sure you look
at the Details tab and verify that you get the "CONNECTED" status also.
That becomes more of an issue if you have multiple databases like us
that were copied from, say, a live database (we do that a lot for
testing/training in separate facilities where we copy a "live" database
to a test database and we have to go in and change the port numbers for
the app servers). The app servers may show as started, but not be
connected due to port conflicts.
Steven Comeau
Manager of Corporate IT Systems
Main Tape
1 Capital Drive, Suite 101
Cranbury, NJ 08512
1-800-526-8273 x332
_____
Sent: Tuesday, October 11, 2005 9:33 AM
Subject: RE: [Vantage] Login in Vantage 8.0 on Server 2003 issues
Thank you, Martin. I am putting this on hold again until I allocate more
time to deal with this. I will keep your email for that time. Thanks
again.
Mario Aguirre
Lakin General Corporation, Inc.
Of martinh@...
Sent: Tuesday, October 11, 2005 2:52 AM
Subject: [Vantage] Login in Vantage 8.0 on Server 2003 issues
Mario,
I've got v8 going on a 2003 server and have come across similar
problems.
If v8 rejects your login it usually means that either the app server
isn't
running or schema changes / DB conversions need to be run. Don't
believe
the explorer the only way I've found to tell if the apps server is
running
is to right click on it and select status. If the status shows the
server
is running if not you'll need to check the logs.
If you need any help in this area feel free to contact me.
Regards
Martin Horton
Group IT Manager
PRD Holdings Ltd
DDI: 01902 639187
Mob: 07770 618909
Email: martinh@...
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On Behalf
Of Mario Aguirre
Sent: 10 October 2005 17:15
Has anyone installed successfully Vantage 8.0 on Server 2003? This is
what I experienced so far:
1. You do not know whether the appserver started or not. You will have
to go to status in each appserver and then it shows as started (the
start is grayed out)...
2. Once you confirm that the appserver started, then you look at your
database and it does show that started.
3. I want to login into the sample database that comes with the
installation (mfgsys80). Previously, the login and password has been
manager / manager. I tried that (per Epicor support) and I have no
success. Does anyone know a valid login and password for the database
that comes with the installation? I just want to verify that Vantage
works before I attempt to convert my 6.1 database. I already tried 3
times and I figure if Vantage installation is not working with their
included sample database, little hope I should have to make it work with
my converted 6.1 database...
Thank you all your help.
Mario Aguirre
YAHOO! GROUPS LINKS
* Visit your group "vantage
<http://groups.yahoo.com/group/vantage> " on the web.
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service <http://docs.yahoo.com/info/terms/> .
SPONSORED LINKS
Manufacturing software
<http://groups.yahoo.com/gads?t=ms&k=Manufacturing+software&w1=Manufactu
ring+software&w2=Membership+database+software&w3=Database+mortgage+softw
are&w4=Pda+database+software&w5=Database+management+software&w6=Database
+marketing+software&c=6&s=188&.sig=OG5F3819UOUOg63i0bu6kA>
Membership database software
<http://groups.yahoo.com/gads?t=ms&k=Membership+database+software&w1=Man
ufacturing+software&w2=Membership+database+software&w3=Database+mortgage
+software&w4=Pda+database+software&w5=Database+management+software&w6=Da
tabase+marketing+software&c=6&s=188&.sig=N5BGdur84p-jyuOomcQdbQ>
Database mortgage software
<http://groups.yahoo.com/gads?t=ms&k=Database+mortgage+software&w1=Manuf
acturing+software&w2=Membership+database+software&w3=Database+mortgage+s
oftware&w4=Pda+database+software&w5=Database+management+software&w6=Data
base+marketing+software&c=6&s=188&.sig=8rvcSQnCqJhTCZu-0Si39A>
Pda database software
<http://groups.yahoo.com/gads?t=ms&k=Pda+database+software&w1=Manufactur
ing+software&w2=Membership+database+software&w3=Database+mortgage+softwa
re&w4=Pda+database+software&w5=Database+management+software&w6=Database+
marketing+software&c=6&s=188&.sig=u3KQrTRPAQfsWIT39aHDkg>
Database management software
<http://groups.yahoo.com/gads?t=ms&k=Database+management+software&w1=Man
tabase+marketing+software&c=6&s=188&.sig=R3CF3ODPY4gwjDZjykQYvw>
Database marketing software
<http://groups.yahoo.com/gads?t=ms&k=Database+marketing+software&w1=Manu
facturing+software&w2=Membership+database+software&w3=Database+mortgage+
software&w4=Pda+database+software&w5=Database+management+software&w6=Dat
abase+marketing+software&c=6&s=188&.sig=lmBkRUiBtvHI1u5dkymDcw>
_____
YAHOO! GROUPS LINKS
_____
Steven Comeau
Main Tape
Cranbury, NJ 08512
1-800-526-8273 x332
_____
again.
Mario Aguirre
Of martinh@...
Mario,
problems.
isn't
believe
running
server
Regards
Martin Horton
Group IT Manager
PRD Holdings Ltd
DDI: 01902 639187
Mob: 07770 618909
Email: martinh@...
Of Mario Aguirre
Mario Aguirre
YAHOO! GROUPS LINKS
SPONSORED LINKS
_____
YAHOO! GROUPS LINKS
_____
