Does anyone know if these two queries are system generated queries or know what process is running them? They are our two heaviest running queries that is impacting performance when it gets ran but can’t pinpoint what is executing the queries to look into.
Query #1:
(@P1 int)
SELECT PROGRESS_RECID,
“SysTaskNum”
FROM “dbo”.“SysTask”
WHERE ((“SysTaskNum” > @P1))
ORDER BY “SysTaskNum” DESC
Query #2:
(@P1 varchar(8),@P2 int)
“company”,
“alertnum”,
“errlognum”
FROM “dbo”.“AlertLog”
WHERE ((“Company” = @P1)
AND (“Alertnum” = @P2))
ORDER BY “company” DESC,
“alertnum” DESC,
“errlognum” DESC
You can use SQL Server Profile to see it “live” (danger Will Robinson)
This method is very intrusive and will blow up your performance. But it can be done.
I was thinking of using Profiler in our test environment where there are minimal processes running and run both the Global Alerts and System Tasks to see if we can determine if it is exactly those processes to narrow it down.
Before going the Profiler route, I ran both global alerts and system tasks but did not see them in SQL Studio in the “recent expensive queries” section in Activity Monitor…
We believe the Process MRP task is running the Query #3 script that is taking a long time. Anyone have any suggestions to improve running the Process MRP since the query runs it wide open with no “where” clause and maybe created “as designed”. Below are our parameters.
Chia - How long does your MRP process take? We run our regen after 2nd shift, which takes about 90 minutes. Our net change takes about 10 minutes, though…
