Make the password for SYSPROGRESS go away
Problem Resolution:
1. Go to Start -> Run -> type in regedit 2. This will bring up your
Registry Editor.
3. Find the HKEY_LOCAL_MACHINE\SOFTWARE\ODBC\ODBC.INI.
4. Find your specific ODBC connection that is setup in your ODBC
datasources and double-click on it.
5. Go up to the Edit -> New -> String Value in the menu.
6. Give your New String Value the name of User ID.
7. Then double-click and give it a value of sysprogress. (Or
whatever your user id is setup to be.) 8. Exit the Registry.
9. Repeat the process for your Password.
10. In the SystemTaskAgent, under ODBC Connection, put in the User
ID and Password above.
11. Stop and start the TaskAgent and ProcessServer for this database.
12. Test your report and you should not get prompted.
--- In vantage@yahoogroups.com, "Dawn Stenbol" <dstenbol@...> wrote:
> When we try to print labels from the MES screen on the shop floor we
> keep getting the request for the SYSPROGRESS password. How can I
make
> this go away and save the password permanently? We are using
8.00.12.
> Thanks.
> Dawn Stenbol
> IT Manager
> Wiza Industries.
> Muskego, WI 53150
keep getting the request for the SYSPROGRESS password. How can I make
this go away and save the password permanently? We are using 8.00.12.
Thanks.
Dawn Stenbol
IT Manager
Wiza Industries.
Muskego, WI 53150
