There is a bug with mandatory field! If the user changes to a
different line (such as on p.o. entry) the system will let you save
even if the manditory field in not populated. I have had a call in
and support has duplicated this problem in both version 8.00.810b and
in the current version of 8.03, but an scr has not been created for
it yet.
it yet.
--- In vantage@yahoogroups.com, "bw2868bond" <bwalker@...> wrote:
> In V8 it is described in the help as such:
> Purpose
> You can indicate that a field is required, or mandatory, by using
the
> Rule Wizard. You do this by first creating a mandatory rule and
then
> adding a mandatory rule action to it. Here's how:
> Within the Customization Tools Dialog, click on the Wizards tab and
> the Rule Wizard tab.
> Click the New Row Rule button.
> For the Rule Description field, enter a description that indicates
> this is a mandatory row rule. For example: MyMandatoryRule
> Now on the Select View list, choose the table, or dataView, that
> contains the field you want to make mandatory. For example: ShipVia
> Set up the rule condition so the Select Field is always equal to
> itself. To do this, select the same option for the Select Field and
> Rule Value lists and then select Equals for the rule condition.
> -bw
> --- In vantage@yahoogroups.com, "bchguessing" <bhepner@> wrote:
> > In 6.1 it was very easy make a field mandatory for the users by
> simply
> > checking madatory box for the field. I'm told by support that I
> need
> > to write code to do this in V8.00.10. I have done a little
> > programming in Visual Basic but never in .Net. Has anyone found
an
> > easier way of making a field mandatory or a generic set of code
> that
> > can be manipulated for any field?
