Double-check your customer/ship to address. Is Address1, Address2, etc. all in the correct location? Sometimes we would have the Address1 field missing a value or Address1 and Address2 inverted and that would cause errors like these. It is possible the street address needs to be in the first address field.
We keep notes on QuickShip issues and this has normally related to an invalid Fedex account number. We see this error when provided an incorrect account number or a number that doesn’t match the shipping address.
@Doug.C – you are correct. The needed information did not get back to the UI. The zip code was invalid for the state (or the city, not sure which).
Interestingly, Epicor Support tried to ship it via UPS and UPS returned a meaningful error message. Not sure why the FedEx information does not get back.
Me again. Same issue has surfaced and shipping via UPS does not give the answer. I can find print monitor logs but not logs that show error messages.
We have an application server, a database server and a “third party apps” server, which is where Quick Ship is. Found the print monitor logs on the third-party apps server, but nothing else, log-wise.
If it’s enabled in your web.config file, then you should have a CarrierXMLFile in your base QuickShip website directory. In there you will find all of the log files pertaining to the shipments.
