Mapping document
We are getting ready to move from an version 8 to the latest and are starting on the DMT process. Are there mapping scripts already built that will pull the fields from old versions into the current Template Builder fields needed?
Also, is there such a document is a checklist of every process in DMT in the order you should follow?
Epicor does offer a package of DMT templates and BAQ scripts to use. In the past I’ve seen a matrix showing the sequence of DMT loads, which I believe is part of the package. You would need to contact your CAM for pricing.
Thanks Jeff.
