Vantage Support often does a great job. I just received excellent support from someone on some APM questions/issues I had.
I think our perception often creates our reality. We have access to a wealth of support resources, including the Epicor support staff, and the volunteer folks here. The difference is that here if no one feels like answering your question, or no one knows, then you're SOL. While not every issue I've raised with Epicor support has been resolved in the way I would have liked it to, they have all been resolved.
-bws
Brian W. Spolarich ~ Manager, Information Services ~ Advanced Photonix / Picometrix
    bspolarich@... ~ 734-864-5618 ~ www.advancedphotonix.com
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of chouse1000
Sent: Tuesday, February 23, 2010 6:37 PM
Subject: [Vantage] Re: Marketing Campaign
Thanks everyone. You are so much better and faster than Vantage Support. How sad is that?!
Thanks again.
Cindy
-bws
Thanks again.
Cindy
--- In vantage@yahoogroups.com, "CharlieSmith" <CSmith@...> wrote:
> Brian is correct, you need to setup defaults, populate the company
> config and then you can access sales related records.
> Charlie Smith
> Smith Business Services / 2W Technologies LLC
> www.vistaconsultant.com <http://www.vistaconsultant.com/> /
> www.2WTech.com
> Of Brian W. Spolarich
> Sent: Tuesday, February 23, 2010 4:32 PM
> Subject: RE: [Vantage] Marketing Campaign
> If you purchased the CRM module then you'll need to make sure that all
> of the setup under Company Maintenance/Modules/CRM is completely done.
> In a new company setup Vantage will yell at you and you won't be able to
> open a Customer record until this is done, but perhaps in a
> conversion/upgrade things work differently.
> You can right-click in each of the fields to open the corresponding
> Entry screens and create a dummy record if nothing else. But you need to
> set these defaults.
> That my first thought, but I've only ever been on V8.03.
> -bws
> Picometrix
> bspolarich@...
> <mailto:bspolarich%40advancedphotonix.com> ~ 734-864-5618 ~
> [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On
> Sent: Tuesday, February 23, 2010 4:19 PM
> Subject: [Vantage] Marketing Campaign
> We have just upgraded from 6.10.543 to 8.03.408B and we are having
> trouble saving the SO lines (which worked fine in the test). When we use
> some of the ones already set up, it says that it is an "Invalid
> Marketing Campaign". I have set up a new one and I still get the same
> error. I have left the dates blank, changed the dates to 01/01/2001 -
> 12/31/2020, changed the dates to 01/01/2001 - 12/31/2010, but none of
> them work. We finally used an old one that was only good for the 2004
> calendar year and it worked, even though it shouldn't have.
> Has anyone else had this problem? Do we have something set up
> incorrectly?
> Thanks,
> Cindy
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> have already linked your email address to a yahoo id to enable access. )
> (1) To access the Files Section of our Yahoo!Group for Report Builder
> and Crystal Reports and other 'goodies', please goto:
> <http://groups.yahoo.com/group/vantage/files/>
> http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
