>since this is a sub menu to Receipt EntryBTW... if you haven't yet customized any subforms... there is a little "gotcha".
Even if the main form isn't being customized, you'll still need to create one that uses the the same name as the subform customization.
The system will look for a matched pair.
--- In vantage@yahoogroups.com, "Cathy" <cathy@...> wrote:
> Just learned something - since this is a sub menu to Receipt Entry - there
> is no Tools menu.
> However , I just right click in the screen and it allowed me to save
> layouts.
> I am just use to using Tools > Save Layouts.
> Thanks, Your email forced me to find check this out.
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of
> b_ordway
> Sent: Friday, May 17, 2013 11:18 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: Mass Receipts - Customization
> Not sure if this will work for you but... sometimes I set sorts with menu
> item "tools, save layouts" instead of code.
> I think the collections V8/E9 are kind of a pain to work with in general.
> And depending on what you want, performance can suffer.
> --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ,
> "cathyattechnologicsys" <cathy@> wrote:
> > In Mass Receipts, we would like the list of PO Line Items to be sorted in
> PO / Line / Rel order under the PO Release and Mass Receipt sections/
> > In customization this is a list (collection).
> > How can I get this list to sort?
