Any idea why Master Pack is printing out weight in pounds but QuickShip is converting to KG’s on the Commercial Invoices?
Andy
Andy
What’s your weight configuration in App Settings?
Any custom reports involved here?
Thank you, checking with the user on this. I will reply when the user responds. I appreciate your help!
Hello,
The user got back to me today.
Ours is set to lbs. already. That is the issue is that it is set to lbs. but converts to kgs for the Canada order.
What would cause it to convert from lbs to kgs? How can I stop it from converting to kgs?
Thanks again!
Andy
No, thank you, it’s for invoicing. The customer is upset that the lbs are being converted to kgs.
Andy
Is it only on the Canadian documents?
That is correct, this only happens on the Canada invoices.
Andy
He did elaborate and said international invoices and that Canada falls into that designation.
Andy
Did you modify the Epicor default QS report?
So, this just started working properly today. I didn’t make a change and the users didn’t make a change. If I learn how this was fixed, I will reply and share the fix. As of right now it fixed itself?!
Andy
Been going around.
