When creating a Master Pack, I want the user to be able to enter multiple Pack IDs as this can be 1- many relationships. I have a quick search set to show all open pack ID’s for an Order. It returns the right data, but I can only select one pack ID, run do the steps and pick another. We sometimes have 100 or more pack ID’s for a given master pack.
can I not return in multiple rows from the search?
Is another way of doing this? Create a master pack, show all open pack ID’s for the order, add all the pack ID’s to the master pack.
Yeah John, create an embedded dashboard that displays the masterpack number you are adding to and the pack ID that you want from shiphead. if you select those results you can copy and then do a paste insert on the summary panel.
Sorry @utaylor when I try that (and thank you BTW) I get he following error, Carton Detail Pack ID must be greater then zero. This occurs if I click paste insert or past update.
John, I can replicate your issue when I copy from an excel sheet where I put the masterpack number = my masterpack number and the pack number = 0.
Something is going on when you are copying or pasting and the pack number is not coming over. That would be my guess. Can you try copying your baq results to excel and then copying from excel into the summary grid? @GTI07094
