Material Allocation against Job order (FIFO)
Hi All,
I want to allocate material before i print pick list for job. So, below step will there for job order issue.
  1. Create & Release Job order.
  2. Automatically Allocate material as per FIFO.( If any such function is available in EPICOR)
  3. Print pick list. ( It should consist of item /qty with Serial number or Batch no/Lot no based on FIFO)
  4. Pick material ( Nothing to do with EPICOR as it is manual activity)
  5. Issue material in EPICOR… ( I want this should be “One Click” for whole picklist issue as material is already allocated to it . It means system know which one to issue against)
Can this be achieved in EPICOR? If yes , How?
Awaiting your reply on it.
V
Hi Vipul,
Did you find a solution to the process above?
We have a similar workflow.
Hi Moe not really… still finding best solution.
V
