Object Name Method Name Frequency Total Execution Time (ms) Average Execution Time (ms) %-Freq Exceeds MS Threshold Longest (ms) Least (ms) Type %-Time
Menu GetRowsWebAccessTranslated 311 87274858 280626 9.66 True 2182722 3013 Ice:BO 0.00
This is for Epicor ERP 10.2.100.9 with 185 companies.
Has anybody seen this before? I couldn’t find reference to it in the release notes and so not sure whether it has been an issue that was resolved or is it something unusual only happening to my environment.
Excerpt from the Server logs shows some complex logic for multiple rows of ice.security table
<Op Utc="2018-08-31T11:42:57.5884917Z" act="Ice:BO:Menu/MenuSvcContract/GetRowsWebAccessTranslated" dur="4263.3284" cli="::1:57125" usr="manager" machine="TEST" pid="7960" tid="114">
<Sql queries="1971" cacheHits="802" time="4105.9966" qryTypeCount="4" />
<Sproc name="[Ice]._ZFW_Menu_GetRows" duration="141.5952" />
<RowEvent table="Menu" method="AfterGetRows" rows="2371" duration="0.15280000000000002" />
<TablesetEvent tsName="MenuTableset" method="AfterGetRows" duration="9.2944000000000013" />
<RowCount tableset="MenuTableset" count="1968" />
<EpiCommand hashCode="-1825340247071956711" queryType="SELECT,SELECT,SELECT" spid="60" table="[Ice].[Security]"><![CDATA[
SELECT
CASE WHEN ( EXISTS (SELECT
1 AS [C1]
FROM [Ice].[Security] AS [Extent1]
WHERE ([Extent1].[Company] = @p__linq__0) AND ([Extent1].[SecCode] = @p__linq__1) AND ([Extent1].[CustWebAvailable] = @p__linq__2)
)) THEN cast(1 as bit) ELSE cast(0 as bit) END AS [C1]
FROM ( SELECT 1 AS X ) AS [SingleRowTable1]
]]></EpiCommand>
<DBStatement type="Boolean" duration="5.0039" rowCount="1" hashCode="-1825340247071956711" dbContextId="eb61b181-2e5f-4a52-8683-3c9d213fd815" />
SELECT
1 AS [C1]
]]></EpiCommand>
<DBStatement type="Boolean" duration="4.7201" rowCount="1" hashCode="-1825340247071956711" dbContextId="eb61b181-2e5f-4a52-8683-3c9d213fd815" />
SELECT
1 AS [C1]
]]></EpiCommand>
