MES Conversion to Kinetic
Can anyone point me to documentation on how to move MES to Kinetic?
Copy the shortcut for MES, right click and in the target put /Mode=DC
This will pull MES up in kinetic.
Classic has /MES in the target location.
You may also need to go into process in menu maintenance and change pages to kinetic. I haven’t switched MES over yet, so I’m sure I’ve missed a thing or two. But this should get you started.
In this menu make sure the pages have Kinetic Enabled checked and select Kinetic as the form to use.
