Lines 42 and 43 of the mfgsys file are for a vantage username and password
to be used to login to the system.
----- Original Message -----
To: <vantage@yahoogroups.com>
Sent: Thursday, March 18, 2010 8:05 AM
Subject: Re: [Vantage] MES Single Sign On?
Can you give an example of where you put it in the *.mfgsys file?
Sent: Fri, 5 March, 2010 19:26:51
Subject: RE: [Vantage] MES Single Sign On?
Yes. Just make sure you use a different login for each MES terminal.
If you have 5 MES terminals, you should have 5 MES Vantage users
(MES_01, MES_02, etc).
Just make the change on each MES PC in c:\client803\ client\config
*.mfgsys file
Also set up a separate domain account for each MES terminal, too, using
the same convention as above.
____________ _________ _________ __
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf
Of k99ja04
Sent: Friday, March 05, 2010 1:58 PM
To: vantage@yahoogroups .com
Subject: [Vantage] MES Single Sign On?
Is it possible to use the Single Sign On feature with MES?
