Hi, does anyone know why MFG-VAR usually come through when the job is completed but in some cases the transaction does not post until the job has been closed?
I’m not sure if’s in connection with the completion of the individual operations.
The MFG-VAR shows up on completion of the job to give you the ability to correct the issue by reversing the complete to stock transaction and add/reduce labor of material transactions.
When you close the job, it is telling the system it’s okay to capture (post) the transactions.
