I am trying to get a mileage calculator to work using map quest.
I found code on line and pieced it together but there is not an assembly in Epicor for JavaScriptSerializer.
“Error: CS0246 - line 182 (7626) - The type or namespace name ‘JavaScriptSerializer’ could not be found (are you missing a using directive or an assembly reference?)”
Is there something else in Epicor that can be used or if anyone has done something like this in epicor who can give me some direction.
Code I am using:
public class MapQuestResponse
public Route[] route { get; set; }
public class Route
public double distance { get; set; }
// Define the button click event handler
private void btnTest_Click(object sender, EventArgs e)
// Get the zip codes from the text fields
string zipCode1 = txtCalHome.Text;
string zipCode2 = txtShpTo.Text;
// Build the URL for the MapQuest API request
string url = string.Format("http://www.mapquestapi.com/directions/v2/route?key=APIKEY&from={0}&to={1}", zipCode1, zipCode2);
// Send the API request and get the response
HttpWebRequest request = (HttpWebRequest)WebRequest.Create(url);
HttpWebResponse response = (HttpWebResponse)request.GetResponse();
Stream stream = response.GetResponseStream();
StreamReader reader = new StreamReader(stream);
string responseText = reader.ReadToEnd();
// Parse the JSON response
JavaScriptSerializer serializer = new JavaScriptSerializer();
MapQuestResponse mapQuestResponse = serializer.Deserialize<MapQuestResponse>(responseText);
// Get the distance from the response and display it in the text field
double distance = mapQuestResponse.route[0].distance;
txtLoad.Text = distance.ToString();
