Is anyone familiar with the calculate MMS feature in epicor? I’ve set up some parts with the necessary values in part maintenance in our test environment. But I’m not sure how to run the process and review calculated MMS.
Using the “Min Max Safety Mass Update” screen, load the parts by selecting the part class, when loaded select individual or all parts, press the “Calculated Selected” button. Review the results, adjust parameters, rinse and repeat.
When happy press “Copy all Proposed”.
Thank you.
