You can then create a dynamic parameter using the partnum field.
The crystal prompt page will appear and give you a list of all the partnum's
in the dataset for you to choose one or more of.
Dines, Tim
Sent: Tuesday, February 16, 2010 3:57 PM
Subject: RE: [Vantage] Modify Existing Filters on Reports
Would it be possible, at least on the Stock Status Report, to duplicate
the RDD and the Crystal Report and then add a parameter field in the
Crystal Report itself? There is no way to monkey with the Time Phased
Report. The only thing to do there is turn on the tracer and write your
own, which would not be an easy task in my opinion.
Tim Dines
Information Technology
Steel Parts Manufacturing, Inc.
801 Berryman Pike
Tipton, IN 46072
Direct: 765-675-5201
Cell: 765-437-1402
Behalf
Of Vic Drecchio
Sent: Tuesday, February 16, 2010 1:06 PM
As far as I know, you cannot add filters to Report Data Definitions even
if you duplicate them. You must create your own BAQ duplicating the
query (if possible).
Behalf
Of advantage
Sent: Tuesday, February 16, 2010 12:05 PM
Subject: [Vantage] Modify Existing Filters on Reports
Has anyone done the following E9.04.505c
Stock Status Report - add the Filter to be able to run it by Part
Time Phase Material Report - add the Filter to be able to run it by Part
Dines, Tim
Tim Dines
801 Berryman Pike
Tipton, IN 46072
Cell: 765-437-1402
Behalf
Of Vic Drecchio
Behalf
Of advantage
