The only other thing I can add is I have had weird behavior when the size of the form or group has been changed to make room so I can move things around. As with your experience I could never get things to behave and had to go back to a clean starting point. Even manually adjusting the form back to its original size wouldn't help.
it seemed to have something to do with either the form's, group's or button's anchor settings (left, right, top, bottom). When the form launched it seemed to want to work with the anchor settings to adjust locations based on them since the customization was changing the size of the form. That looked to throw off my adjustments to the button locations. As I mentioned to get things straightened out I had to go back to a clean start and then carefully move things without changing the size of the underlying form/group. in one case I remember doing something in the load event as mentioned by another poster.
Jim Kinneman
Encompass Solutions, Inc
Jim Kinneman
--- In vantage@yahoogroups.com, Adrian Lauchlan <adrianlauchlan@...> wrote:
> That's exactly what I've had to end up doing. I had to go back to the
> previous customisation and start all over again as trying to move the
> buttons back to their original position didn't work.
> Regards
> Adrian Lauchlan
> Inceptum Projects Ltd
> mobile 07852 270968
> You can now call me on my Skype Number
> skype +44 (0)208 123 5065
> The information in this email including any attachments is intended only for
> the exclusive use of the person or body it is addressed to. It may contain
> confidential and privileged material that may be subject to legal privilege.
> It may not be disclosed, disseminated, re-transmitted or distributed without
> the permission of the sender. If you have received this email in error,
> please delete it from your system and contact the sender. Please note that
> it is the recipient's responsibility to check for viruses and Inceptum
> Projects Ltd will not be held responsible for any damages arising from virus
> infections.
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of
> Kevin Simon
> Sent: 10 February 2012 18:12
> To: vantage@yahoogroups.com
> Subject: RE: [Vantage] Moving buttons
> Adrian,
> I'd love to know if you find a solution. I've seen this in some forms.
> Notably, when you edit one of the UD table maintenance programs, the
> "SEARCH" button is usually one that likes to revert to its original
> position. I've gotten to the point where I just design my screens so that I
> don't have to move that button.
> Kevin
> [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On
> Behalf Of
> adrian.lauchlan
> Sent: Friday, February 10, 2012 12:55 PM
> Subject: [Vantage] Moving buttons
> I was rearranging a menu - Price List Inquiry - which has three buttons on
> the search tab - custid, ship to and part search buttons. When I moved these
> buttons they looked fine whilst in customisation mode but when I switched
> that off and called up the menu they were in totally different positions. I
> tried clearing cache, logging off and logging on but all to no avail. But
> when I went into the customisations they were exactly where I had put them.
> Any suggestions as to why?
