Thanks - I'll check with our company president to see if he has it.
Rick
Rick
> From: sarah.vareschi@...[SMTP:sarah.vareschi@...]
> Reply To: vantage@egroups.com
> Sent: Thursday, September 28, 2000 11:21 AM
> Subject: RE: [Vantage] MOVING TO 4.0/ADDING A CITRIX SERVER
> Hi Rick,
> Your right, the tutorial in 4.0 is not the same as in 3.0. You can
> however,
> still install the 4.0 training database, and you can install the 4.0
> training 'tutorial' although it is different from the 3.0 tutorial (I
> don't
> like it as much, but that's just me).
> To install the 4.0 training database, all you need to do is check off
> 'install training shortcuts' during the client install. To install the
> tutorial, there is a separate disk for it that is disk 2 of your vantage
> 4.0
> cd case. It is very easy to install, the instructions are on page 43 of
> the
> vantage 4.0 install guide you can get on-line.
> Sarah
> We no longer allow attachments to files. To access/share Report Files,
> please go to the following link: http://www.egroups.com/files/vantage/
> (Note: If this link does not work for you the first time you try it, go
> to www.egroups.com, login and be sure to save your password, choose My
> Groups, choose Vantage, then choose Files. If you save the password, the
> link above will work the next time you try it.)
