MRP and Customer Part Numbers
Wait, Customer Number is not a native field in Job Entry. Did you check to see if it was added to the screen?
I tried a couple of different combinations going through MRP and was not successful in getting it to populate the Customer Number. I did use the Order Job Wizard to create Job and it did pull the Customer Number into the Job. Is it possible that the old Jobs had been created using the Order Job Wizard?
The jobs were created with MRP based off of the Sales Order demand that comes in through EDI.
Those Unfirm jobs are then firmed up and put into production.
It will not set it as PartNum. Run this
SELECT * FROM Erp.JobHead WHERE XRefPartNum IN (SELECT XPartNum FROM Erp.CustXPrt WHERE CustNum = 23)
There is no XRefPartNum in the Erp.Part table though.
Meant JobHead oops.
