MRP Going straight to Canceled
Running into an issue in 10.2.200.14 with when I submit an MRP job it goes to the status of CANCELED immediately as shown in system monitor. We are still in the implementation phase and E10 LIVE was recently refreshed from TEST and we did update the user/pass in system agent. The submission doesn’t even create a log file.
Just to add to this, other areas of Epicor that are dependent on the task agent are working like reports and other processes we submit.
Thank you
Can you verify the password is saving in system agent maintenance. I could not get it to save with a login using SSO. Had to use a standard Epicor login application pool to login to the system. Then is the task agent config and the system agent user and password the same in the system. I assume allow impersonation is enabled for your system agent user.
