The Planning Time Fence is your culprit on the cancel/re-enter job messages.
Doubtful the reschedule in/out values are hurting you.
You can avoid the increase/decrease job qty messages by locking your job qty's. (We customized job entry to lock ours automatically when a job is engineered.)
Don't be confused by the messages you see in time phase. All these messages aren't necessarily 'exceptions' that would be presented via Planners or Buyers WB. Time phase shows every message (whether it is an 'exception' or not).
Rob Brown
Rob Brown
--- On Tue, 6/24/08, bw2868bond <bwalker@...> wrote:
Subject: [Vantage] Re: MRP Issues with Vantage 8.03.404B
Date: Tuesday, June 24, 2008, 2:32 PM
That would mostlikely solve most of your issues.
However; you will then have to deal with all the (my opinion) absurd
amount of reschedule/cancel/ reorder message MRP will then generate.
This behavior identified on bug number 50580 slated to be fixed in
patch 8.03.405A and/or Service Pack 8.03.406
--- In vantage@yahoogroups .com, "swrhoadesfti" <SRhoades@.. .> wrote:
> Bw, yes we have Reschedule deltas and Planning time fences setup
for
> all of our product Classes. Receive Time:5, Planning Time Fence:3,
> Reschedule Out:10, Reschedule In:3. Should we look at setting
these
> to 0?
> --- In vantage@yahoogroups .com, "bw2868bond" <bwalker@> wrote:
> > Would you happen to have reschedule deltas or planning time
fences
> > set up?
> > bw
> > --- In vantage@yahoogroups .com, "swrhoadesfti" <SRhoades@> wrote:
> > > Hi everyone, we recently moved to Vantage 8.03.404B and have
been
> > > having several problems with MRP. I have been advised from
> > Technical
> > > support to upgrade to 8.03.405, however, I am hesitant to do
this
> > > based on the amount of work it will take to update all of our
add-
> > on
> > > & 3rd Party modules. I am looking at about a months worth of
> work
> > in
> > > order to do this. I also have over 8 different issues with
MRP,
> > and
> > > I have no guarantee that my problems will be fixed in
8.03.405.
> > > Therefore, before I take this leap of faith I am asking 2
> > questions.
> > > 1) Are there any of you using 8.03.404B and MRP that are having
> > > issues that you didn't have when running earlier code?
> > > 2) Are there any of you that had problems with MRP in 8.03.404B
> > that
> > > went to 8.03.405 and there problems were fixed?
> > > Some of the MRP issues are:
> > > MRP suggests new Jobs, when there is no demand.
> > > MRP suggest cancelling jobs, and then asks you to start new
ones.
> > > MRP suggests cancelling jobs, and then does not suggest
anything
> > when
> > > the balance goes negative.
> > > MRP suggests new jobs but with incorrect start dates, due dates
> > > With a split job, only 1 of the jobs will get suggestion
> activities.
> > > MRP suggests to increase released jobs to minimum Lot Size
> > eventhough
> > > there is no demand
> > > MRP suggestions to Reduce/Increase Qty on Released Jobs
> > > I would love to hear from anyone on this issue. Thanks!
