The receipt quantity drops to zero because none have been completed on
the job. The receipt quantity would usually equal the completed
quantity minus the received to stock quantity
Gary
Of leann_37
Sent: 24 July 2007 01:34
Subject: [Vantage] Re: MRP question
According to Epicor, a job is live to scheduling and capacity until
closed- not just completed. The receipt quantity drops to 0, but it
is still considered "live" until it is closed.
Hope this helps!
- leAnn
"Jasper Recto" <jrecto@...> wrote:
happens to the material requirements?
Gary
Of leann_37
Hope this helps!
- leAnn
>for those 10 pcs.
> Lets assume we have a SO demad for 10 pcs. MRP would create a job
>assumes you will continue and finish the last piece.
> If the job is open for 10pcs and only 9 are completed, Vantage
> If we close the job short 1piece, Vantage would make a new MRP jobfor 1 because there is still a demand.
>MRP assume that no more activity will be performed on that job? What
> What whould happen if the job was just checked as completed. Does
> Does MRP assume that any outstanding material requirements thatwere associated with the job go away?
> Will MRP create a new Job for the remaining 1 pc balance?[Non-text portions of this message have been removed]
> Thanks,
> Jasper
