Multi-select in Kinetic Search Form
In Classic, when you did a search, you could highlight a range of results by clicking on the first selection, holding down control, and clicking on the end selection:
In Kinetic, when you do the same search, it doesn’t appear that you can easily select a range of rows:
I know that I can click on each of the ‘Selected’ checkboxes, but if I want to select 50 or so records, that is pretty time consuming compared to the click/control-click option.
Anyone found a workaround for this?
If I hold shift down it does it for me, though I’m on 2024.1 so ymmv
SelectMultiple
We are on 2024.2 and cannot use the same Shift+Click process to select multiple rows at a time. Are there some changes in Application Studio I have to make before that becomes functional?
hey, i am facing the same issue. did you find anything on this?
To select a range of rows in the search, it appears that clicking the checkbox of the last row in the range does not select the other rows - you have to click one of the other columns on that row.
I just now went and checked it and it seems like the Shift+Click is working for us on 2025.1.11
