https://www.amazon.com/MICR-Check-Position-Gauge-Plus/dp/B074J34766/
Older Version:
https://www.amazon.com/Elfring-Fonts-Inc-MICRgauge-Position/dp/B00482U8WG/
Older Version:
Is there a version for when the PDF creator automatically sets the rendered output to “Shrink to Fit”?
No! I just find a window where the sun is shining bright enough and the paper shows thru, then I used to use a regular check to align stuff
– close.
I used to use this when checking drawing revisions. put the original and the new one up to a window, to see the differences. Worked great when everything was printed on vellum. Not so much since we no use paper. ![]()
