Need Help with Vantage Credit Cards
Matt
Â
1. The way you change the credit card number is you have to delete the number then tab out of the field to be able to change the credit card type.
Â
2. The table that stores the credit card number only stores the last one used. You cannot keep multiples.
Â
3. Current setup for purging is 99 days.
Â
Â
Wendy
----- Original Message ----
Sent: Friday, July 18, 2008 9:14:19 AM
Subject: [Vantage] Need Help with Vantage Credit Cards
Here are a few questions that we are running across as we attempt to setup the credit card module in Vantage.
1   How do you change the Credit Card number that is used on the account? It defaults to the last used Credit Card on the account, however we have customers who use different credit cards when they place a new order.. As it stands right now I can not change the credit card number when inputting a new order.
2Â Â Â When I am able to input different credit card numbers will I be able to use the drop down and recall customers credit card information?
3Â Â Â Any ideas on how long you can set the purge dates?
Please let us know if you have any advice, we have a call into support, but you know how that can go.
1   How do you change the Credit Card number that is used on the account? It defaults to the last used Credit Card on the account, however we have customers who use different credit cards when they place a new order. As it stands right now I can not change the credit card number when inputting a new order.
