Need Help writing to Excel
I have the opposite problem. I'm trying to transfer order lines from an excel spreadsheet into the Transfer Order screen.
I can get it as far as creating the excel object, creating a dataset of the spreadsheet contents, but how do I set the datasource of the transfer order lines grid in the summary screen to use my dataset ? Is that even possible ?
Tx
B
--- In vantage@yahoogroups.com, "dgodfrey_amc" <dgodfrey_amc@...> wrote:
> I am trying to read and write to an excel file through the Customization editor. I am using an OleDbConnection. I am able to read from the excel file this way but I can not write to a file. Does anyone have any examples of how to write back a dataset or even just a row using OleDbConnection OR
> does anyone have a better way to do this I would really appreciate it.
I have used your approach only to read information from a very structured Excel Workbook.
To read AND write to Excel I use the Microsoft.Office.Interop.Excel assembly. This exposes all of the capabilities of Excel and lets me manipulate the spreadsheet anyway I need to.
You may need to copy Microsoft.Office.Interop.Excel.dll into the Epicor /client directory. After that use the add custom assembly and the appropriate using/imports Microsoft.Office.Interop.Excel statement
Since I don't do this that often I usually Google on how to call the various methods of Microsoft.Office.Interop.Excel.
Jim Kinneman
Senior Consultant
Encompass Solutions
I will save you the google step. This will export your materials out of a quote.
Tom Osen
Imports Microsoft.Office.Interop.Excel
Private Sub CostedBOM()
'// ** Place Event Handling Code Here **
Dim edvQuoteMtlView As EpiDataView = CType(oTrans.EpiDataViews("JobMtl"), EpiDataView)
Dim edvVendPartView AS EpiDataView = CType(oTrans.EpiDataViews("VendPart"), EpiDataView)
Dim edvVendPBrkView AS EpiDataView = CType(oTrans.EpiDataViews("VendPBrk"), EpiDataView)
Dim edvQuoteHead As EpiDataView = CType(oTrans.EpiDataViews("QuoteHed"), EpiDataView)
Dim inQuoteNum, inQuoteLine, inNetWeight As Integer
Dim workbookLocation, strIncoTerms, strVendor As String
workbookLocation = "\\fileserver\doclinks\quote\" + CStr(edvQuoteMtlView.dataView(edvQuoteMtlView.Row)("QuoteNum")) + "_QuoteWorkbook.xls"
' check to see if the file is not open and exists
If System.IO.File.Exists(workbookLocation) = True _
And Not IsFileOpen(workbookLocation) Then
Dim oExcel As Microsoft.Office.Interop.Excel.Application
oExcel = CreateObject("Excel.Application")
oExcel.Application.Visible = False
Dim oWorkbooks As Object = oExcel.Application.Workbooks.Open(WorkbookLocation)
Dim workbookRow As Integer = 15
Dim strRange, quoteTeam, strClass As String
Dim inLeadTime, inMOQ, inColumn As Integer
Dim inOnHandQty, inAveCost As Decimal
Dim decPriceBreak(8, 1) As Decimal
Dim blSPL, blWholeUnit As Boolean
oWorkbooks = oWorkbooks.Worksheets("Costed BOM")
oExcel.Application.Sheets("Costed BOM").Select
' Set the part weight to the FG part
quoteTeam = edvQuoteHead.dataView(0)("Character08")
PartInfo(oExcel.Application.Cells(1, 5).Value, inLeadTime, inOnHandQty, inNetWeight, blWholeUnit, quoteTeam)
inLeadTime = 0
oExcel.Application.Cells(4, 5).Value = inNetWeight
oExcel.Application.Cells(8, 14).Value = System.DateTime.Now
' msgbox("Lead time at Start = " &amp; CStr(inLeadtime))
For i as integer = 0 to edvQuoteMtlView.dataView.Count - 1
' If edvQuoteMtlView.dataView(edvQuoteMtlView.Row)("QuoteNum") = inQuoteNum _
' And edvQuoteMtlView.dataView(edvQuoteMtlView.Row)("QuoteLine") = inQuoteLine Then
' copy and paste the row so we don't care how many parts this BOM has. We can go to the limit of Excel rows
oExcel.Application.Range("15:15").Select
oExcel.Application.Selection.Copy
workbookRow += 1
strRange = CStr(workbookRow) + ":" + CStr(workbookRow)
oExcel.Application.Range(strRange).Select
oExcel.Application.Selection.Insert(-4121)
' Initalize the variables for this part
inLeadTime = 0
inMOQ = 0
inOnHandQty = 0
inAveCost = 0
PartCost(edvQuoteMtlView.dataView(i)("PartNum"), inAveCost)
'Find the supplier price list information
If edvQuoteMtlView.dataView(i)("BuyIt") _
And edvQuoteMtlView.dataView(i)("VendorNum") <> 0 Then
SupplierPriceList(edvQuoteMtlView.dataView(i)("VendorNum"), edvQuoteMtlView.dataView(i)("PartNum"), inLeadTime, inMOQ, blSPL)
For idxVendPart As Integer = 0 to edvVendPartView.dataView.Count - 1
' inLeadTime = edvVendPartView.dataView(idxVendPart)("LeadTime")
strIncoTerms = edvVendPartView.dataView(idxVendPart)("ShortChar01")
strVendor = edvVendPartView.dataView(idxVendPart)("VendorName")
' For inBrk As Integer = 0 to 8
' decPriceBreak(inBrk, 1) = edvVendPartView.dataView(inBrk)("BaseUnitPrice")
' Next
Next
End If 'edvQuoteMtlView.dataView(i)("VendorNum") &lt;&gt; 0
' msgbox( edvQuoteMtlView.dataView(i)("PartNum") &amp; " Lead time after SPL = " &amp; CStr(inLeadtime) &amp; " " &amp; quoteTeam)
PartInfo(edvQuoteMtlView.dataView(i)("PartNum"), inLeadTime, inOnHandQty, inNetWeight, blWholeUnit, quoteTeam)
' msgbox("Lead time after PartInfo = " &amp; CStr(inLeadtime) &amp; " " &amp; quoteTeam)
If inLeadTime = 0 Then
inLeadTime = edvQuoteMtlView.dataView(i)("LeadTime")
' msgbox("Lead time after screen = " &amp; CStr(inLeadtime) &amp; " " &amp; quoteTeam)
End If
oExcel.Application.Cells(workbookRow, 1).Value = Math.Ceiling((inLeadTime / 7)) ' RoundUp((inLeadTime / 7)) 'A
' oExcel.Application.Cells(workbookRow, 2).Value = quoteTeam 'B
oExcel.Application.Cells(workbookRow, 3).Value = edvQuoteMtlView.dataView(i)("PartNum") 'C
oExcel.Application.Cells(workbookRow, 4).Value = edvQuoteMtlView.dataView(i)("Description") 'D
oExcel.Application.Cells(workbookRow, 5).Value = edvQuoteMtlView.dataView(i)("QtyPer") 'E
oExcel.Application.Cells(workbookRow, 6).Value = edvQuoteMtlView.dataView(i)("IUM") 'F
If blWholeUnit Then
oExcel.Application.Cells(workbookRow, 7).Value = "Yes" 'G
Else
oExcel.Application.Cells(workbookRow, 7).Value = "No"
End If
oExcel.Application.Cells(workbookRow, 8).Value = inMOQ 'H
oExcel.Application.Cells(workbookRow, 9).Value = edvQuoteMtlView.dataView(i)("EstScrap") / 100 'I
' oExcel.Application.Cells(workbookRow, 10).Value = edvQuoteMtlView.dataView(i)("Number13") '
oExcel.Application.Cells(workbookRow, 12).Value = inAveCost 'L
' oExcel.Application.Cells(workbookRow, 11).Value = edvQuoteMtlView.dataView(i)("Number15") '
oExcel.Application.Cells(workbookRow, 14).Value = inOnHandQty 'N
' If SPL then use the price breaks for the data else use the average cost
oExcel.Application.Cells(workbookRow, 18).Value = edvQuoteMtlView.dataView(i)("Number11") 'R
oExcel.Application.Cells(workbookRow, 24).Value = edvQuoteMtlView.dataView(i)("Number12") 'X
oExcel.Application.Cells(workbookRow, 30).Value = edvQuoteMtlView.dataView(i)("Number13") 'AD
oExcel.Application.Cells(workbookRow, 36).Value = edvQuoteMtlView.dataView(i)("Number14") 'AJ
oExcel.Application.Cells(workbookRow, 42).Value = edvQuoteMtlView.dataView(i)("Number15") 'AP
oExcel.Application.Cells(workbookRow, 48).Value = edvQuoteMtlView.dataView(i)("Number16") 'AV
oExcel.Application.Cells(workbookRow, 54).Value = edvQuoteMtlView.dataView(i)("Number17") 'BB
oExcel.Application.Cells(workbookRow, 60).Value = edvQuoteMtlView.dataView(i)("Number18") 'BH
oExcel.Application.Cells(workbookRow, 66).Value = edvQuoteMtlView.dataView(i)("Number19") 'BN
oExcel.Application.Cells(workbookRow, 71).Value = strVendor 'BS
oExcel.Application.Cells(workbookRow, 72).Value = strIncoTerms 'BT
Next
oExcel.Application.ActiveWorkbook.Save
oExcel.Application.Workbooks.Close()
RCO(oWorkbooks)
oExcel.Application.Quit()
RCO(oExcel)
oWorkbooks = Nothing
oExcel = Nothing
GC.Collect()
MsgBox("Costed BOM has finished downloading into the quote workbook." , MsgBoxStyle.OkOnly , "Costed BOM" )
Else
MsgBox("something is wrong with the file " & vbcrlf & "File location is " & workbookLocation _
& vbcrlf & "Is the file open " & CStr(IsFileOpen(workbookLocation)), MsgBoxStyle.OkOnly or MsgBoxStyle.Critical, "Quote Workbook Information" )
End If
edvQuoteMtlView = Nothing
edvVendPartView = Nothing
edvVendPBrkView = Nothing
edvQuoteHead = Nothing
End Sub
Public Sub RCO(obj As Object)
' This releases all the com objects that where created
Try
Dim intRel As Integer = 0
Do
intRel = System.Runtime.InteropServices.Marshal.ReleaseComObject(obj)
Loop While intRel > 0
Catch ex As Exception
msgbox("Error releasing object" & ex.ToString,vbOKOnly,"Close Excel Error")
obj = Nothing
End Try
End Sub
> Jim Kinneman
> Senior Consultant
> Encompass Solutions
I can't seem to find the appropriate dll. I did a search for just "Interop" and received nothing.
> Jim Kinneman
> Senior Consultant
> Encompass Solutions
The Microsoft Office dll's live in the Global Assembly Cache (GAC), which is not accessible through normal windows explorer methods. You can use command prompt to get it at though, and copy the file elsewhere.
If you open command prompt, make sure your in the C: directory, and cd to Windows\assembly\GAC\Microsoft.Office.Interop.Excel, and then dir the directory, you should see a few folders. Depending on the version of Excel you have, the folder names will be different. Ours is 2007, so the folder is 12.0.0.0__71e9bce111e9429c. If you then cd there, and dir that directory, you will see the Microsoft.Office.Interop.Excell.dll file. You can then copy it wherever you like.
> > Jim Kinneman
> > Senior Consultant
> > Encompass Solutions
OK, am really having a difficult time accessing an Excel file. I have been able to get it to work on my machine and thought everything was great until I deployed it. A user tried the customization and got a
-- "Format of the initialization string does not conform to specification starting at index ..." error.
my code was
'-- MyConnection = New System.Data.OleDb.OleDbConnection("provider=Microsoft.Jet.OLEDB.4.0;data source='" & myPath & " '; " & "Extended Properties=Excel 8.0;")
'-- MyCommand = New System.Data.OleDb.OleDbDataAdapter("select * from [sheet1$] where InActive= False", MyConnection)
'-- MyCommand.Fill(dsECODataSet, "ECORecords")
I starting looking in the history threads here and found someone talking about using this string
-- Imports Microsoft.Office.Interop.Excel
So I tried and tried using the Excel.Application and had no success compiling
Error: BC30002 - line 1572 (2186) - Type 'Excel.Application' is not defined.
Error: BC30002 - line 1573 (2187) - Type 'Excel.Workbook' is not defined.
Error: BC30002 - line 1574 (2188) - Type 'Excel.Worksheet' is not defined.
Error: BC30002 - line 1575 (2189) - Type 'Excel.Range' is not defined.
Error: BC30002 - line 1581 (2195) - Type 'Excel.ApplicationClass' is not defined.
Error: BC30002 - line 1589 (2203) - Type 'Excel.Range' is not defined.
here was my test subroutine:
Private Sub Button1_Click_1(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
Dim xcFileDialog As New OpenFileDialog()
xcFileDialog.Filter = "Excel Spreadsheet Files|*.xls"
xcFileDialog.Title = "Select excel spreadsheet file!"
xcFileDialog.CheckFileExists() = True
If xcFileDialog.ShowDialog = Windows.Forms.DialogResult.OK Then
If Not String.IsNullOrEmpty(xcFileDialog.FileName) Then
TextBox1.Text = xcFileDialog.FileName
End If
End If
If Not String.IsNullOrEmpty(TextBox1.Text) Then
Dim xlApp As Excel.Application
Dim xlWorkBook As Excel.Workbook
Dim xlWorkSheet As Excel.Worksheet
Dim range As Excel.Range
Dim rCnt As Integer
Dim cCnt As Integer
Dim Obj As Object
Dim msg As String
xlApp = New Excel.ApplicationClass
xlWorkBook = xlApp.Workbooks.Open(TextBox1.Text)
xlWorkSheet = xlWorkBook.Worksheets("sheet1")
range = xlWorkSheet.UsedRange
For rCnt = 1 To range.Rows.Count
For cCnt = 1 To range.Columns.Count
Obj = CType(range.Cells(rCnt, cCnt), Excel.Range)
msg = msg & Obj.value & "; "
Next
msg = msg & Chr(13) & Chr(10)
Next
MsgBox(msg)
xlWorkBook.Close()
xlApp.Quit()
releaseObject(xlApp)
releaseObject(xlWorkBook)
releaseObject(xlWorkSheet)
End If
MsgBox("Test Complete")
End Sub
I know this is long but I am wanting to give as much info so hopefully someone can help explain where I am going wrong.
Dan
Based on how your code is setup, when you import the Excel namespace in the line Imports Microsoft.Office.Interop.Excel, and then use Excel.Application to declare some of your variables using Excel.Application, you are in essence trying to use it twice. When I use Excel, I only use Imports Microsoft.Office.Interop. Then, your variable declarations should work just fine. You could also keep your current Imports, and change all declarations to remove the Excel., but it's nice to do it the other way in case you are also using Word, Outlook, etc.
> my code was
> End If
> End If
> Dim rCnt As Integer
> Dim cCnt As Integer
> Dim Obj As Object
> Dim msg As String
> Next
> Next
> MsgBox(msg)
> xlWorkBook.Close()
> xlApp.Quit()
> End If
> End Sub
> Dan
I use syncfusion.XlsIO imports that is included with Vantage. The dll's are in
the client folder.
This is an example that will export the Part number and description to Excell.
(I limited this example to Partnum < "8")
There was 2 checkboxes on the form checkbox 1 to save the excel in csv format
and checkbox 2 to save in Excel worksheet
I had to use the Option Explicit line above the imports or I got a lot of the
undefined also.
'// Custom VB.NET code for UD01Form
Option Explicit
Imports System
Imports System.Data
Imports System.Diagnostics
Imports System.Windows.Forms
Imports System.ComponentModel
Imports Microsoft.VisualBasic
Imports Epicor.Mfg.UI
Imports Epicor.Mfg.UI.FrameWork
Imports Epicor.Mfg.UI.ExtendedProps
Imports Epicor.Mfg.UI.FormFunctions
Imports Epicor.Mfg.UI.Customization
Imports Epicor.Mfg.UI.Adapters
Imports Epicor.Mfg.UI.Searches
Imports Epicor.Mfg.BO
Imports syncfusion.XlsIO
   Private Sub btnEpiCustom2_Click(ByVal Sender As Object, ByVal Args As
System.EventArgs) Handles btnEpiCustom2.Click
     Dim xl As ExcelEngine = New ExcelEngine()
                Dim xlApp As IApplication = xl.Excel
                Dim wkbk As IWorkbook = xl.Excel.Workbooks.Create(1)
                Dim sht1 As IWorksheet = wkbk.Worksheets(0)
                sht1.Range("A1").Text = "Part Number"
                sht1.Range("B1").Text = "Description"
         Dim whereClause As String = "PartNum < '8' "
            Dim recSelected As Boolean
            Dim dsSearch As DataSet
             Dim cnt as integer
        Dim xlcnt as Integer = 2
        Dim ddpart as string
        Dim ddpartdesc as string
        dsSearch =
Epicor.Mfg.UI.FormFunctions.SearchFunctions.listLookup(oTrans,"PartAdapter",
recSelected, false, whereClause)
           If recSelected Then
      For cnt = 0 to dsSearch.Tables(0).rows.count - 1
                ddpart = dsSearch.Tables(0).Rows(cnt)("PartNum")
               ddpartDesc =
dsSearch.Tables(0).Rows(cnt)("PartDescription")
     sht1.Range("A"+xlcnt.tostring()).Text = ddpart
     sht1.Range("B"+xlcnt.tostring()).Text = ddpartdesc
     xlcnt = xlcnt + 1
      next
                  end if
    if txtEpiCustom2.text <> "" then
              if chkEpiCustom1.checked then
               wkbk.SaveAs(txtEpiCustom2.text & ".csv",",")
             ' wkbk.SaveAs("c:\test.csv",",")
              end if
       if chkEpiCustom2.checked then
              wkbk.SaveAs(txtEpiCustom2.text & ".xls",
ExcelSaveType.SaveAsXLS)
            ' wkbk.SaveAs("c:\test.xls", ExcelSaveType.SaveAsXLS)
          end if
  end if
                wkbk.close()
                xl.ThrowNotSavedOnDestroy = False
                xl.dispose()
    Messagebox.show("Finished writing to Excel")
    End Sub
Â
Sent: Mon, February 28, 2011 8:18:06 AM
Subject: [Vantage] Re: Need Help writing to Excel
Â
> my code was
>using this string
>defined.
> End If
> End If
> Dim rCnt As Integer
> Dim cCnt As Integer
> Dim Obj As Object
> Dim msg As String
> Next
> Next
> MsgBox(msg)
> xlWorkBook.Close()
> xlApp.Quit()
> End If
> End Sub
> Dan
Was there any referencing that you needed to do for this to work. I pasted in your code and it is not working for me. Here was the error.
Error: BC40056 - line 28 (28) - Namespace or type specified in the Imports 'syncfusion.XlsIO' doesn't contain any public member or cannot be found. Make sure the namespace or the type is defined and contains at least one public member. Make sure the imported element name doesn't use any aliases.
Error: BC30002 - line 1573 (2187) - Type 'ExcelEngine' is not defined.
Error: BC30002 - line 1574 (2188) - Type 'IApplication' is not defined.
Error: BC30002 - line 1575 (2189) - Type 'IWorkbook' is not defined.
Error: BC30002 - line 1576 (2190) - Type 'IWorksheet' is not defined.
I am working in 8.03.407C
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of DD
Sent: Monday, February 28, 2011 7:13 AM
Subject: Re: [Vantage] Re: Need Help writing to Excel
the client folder.
undefined also.
Option Explicit
Imports System
Imports System.Data
Dim cnt as integer
dsSearch =
If recSelected Then
ddpartDesc =
xlcnt = xlcnt + 1
next
end if
end if
end if
end if
wkbk.close()
xl.dispose()
End Sub
From: bobschnable <bschnable@...<mailto:bschnable%40deephole.com>>
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, "dgodfrey_amc" <dgodfrey_amc@...> wrote:
> my code was
>using this string
>defined.
> End If
> End If
> Dim rCnt As Integer
> Dim cCnt As Integer
> Dim Obj As Object
> Dim msg As String
> Next
> Next
> MsgBox(msg)
> xlWorkBook.Close()
> xlApp.Quit()
> End If
> End Sub
> Dan
I don't know what I am doing worng but there must be something either systemiatically wrong with my machine or I am missing some steps that are basic to VB that I am not familiar with because I did remove the ".Excel" from the import line and still I am erroring out.
I tried the other suggestion as well and nothing in that front also. Do you reference anything specific as well?
Dan
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of bobschnable
Sent: Monday, February 28, 2011 6:18 AM
> my code was
> End If
> End If
> Dim rCnt As Integer
> Dim cCnt As Integer
> Dim Obj As Object
> Dim msg As String
> Next
> Next
> MsgBox(msg)
> xlWorkBook.Close()
> xlApp.Quit()
> End If
> End Sub
> Dan
In customization select tools / assembly reference manager
choose the Add Custom Reference button.
Use the dropdown on the bottom right to view all files instead of Application
Assemblies
add the following 2 dll's
syncfusion.XlsIO.Base.dll
syncfusion.XlsIO.windows.dll
I am on 8.03.409A and this was also in 8.03.405 so should work for you.
If you are still having trouble then I will send my contact info to your email
offline.
Doug
To: "vantage@yahoogroups.com" <vantage@yahoogroups.com>
Sent: Mon, February 28, 2011 11:59:15 AM
Subject: RE: [Vantage] Re: Need Help writing to Excel
Â
the client folder.
undefined also.
Option Explicit
Imports System
Imports System.Data
Dim cnt as integer
dsSearch =
If recSelected Then
ddpartDesc =
xlcnt = xlcnt + 1
next
end if
end if
end if
end if
wkbk.close()
xl.dispose()
End Sub
able
> my code was
[sheet1$]
>using this string
>defined.
> End If
> End If
> Dim rCnt As Integer
> Dim cCnt As Integer
> Dim Obj As Object
> Dim msg As String
> Next
> Next
> MsgBox(msg)
> xlWorkBook.Close()
> xlApp.Quit()
> End If
> End Sub
> Dan
Here is a sample of my code that works.
My Imports statements:
Imports System
Imports System.Data
Imports Microsoft.VisualBasic.Strings
Instantiating Word for the first time, and declaring some Word documents
Dim wrd As New Word.Application
Dim Quote As Word.Document
Dim QuoteLineAdd As Word.Document
wrd.Visible = True
Quote = wrd.Documents.Open("Y:\Customers\Quotes\Quote Form.docx")
Later in the code, I also instantiate Outlook, and create a new message
Dim olk As New Outlook.Application
Dim olkMsg As Outlook.MailItem = olk.CreateItem(Outlook.OlItemType.olMailItem)
Like I said in my earlier post, I use Imports Microsoft.Office.Interop only, and that way I can use both Word and Outlook. The same goes for Excel. The only custom assemblies I have added are Microsoft.Office.Interop.Outlook and Microsoft.Office.Interop.Word, as highlighted in the procedure I posted last week.
> Dan
> --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, "dgodfrey_amc" <dgodfrey_amc@> wrote:
> > my code was
> > End If
> > End If
> > Dim rCnt As Integer
> > Dim cCnt As Integer
> > Dim Obj As Object
> > Dim msg As String
> > Next
> > Next
> > MsgBox(msg)
> > xlWorkBook.Close()
> > xlApp.Quit()
> > End If
> > End Sub
> > Dan
I am having another problem. I am using the Excel.Application option to read and hopefully write to the spreadsheet. As of right now I can not even open the spreadsheet. All of the code compiles fine, but I get runtime errors. Right now I am getting
"Attempted to read or write protected memory. This is often an indication that other memory is corrupt."
When I execute xlWorkBook = xlApp.Workbooks.Open(txtECOFile.Text)
Here is my code. Does anyone see anything that wrong with what I am coding? The file is definitely NOT protected and it is sitting on my C drive.
Private Sub TestingExcelApplication()
Dim rCnt As Integer
Dim cCnt As Integer
Dim Obj As Object
Dim msg As String = ""
Try
If System.IO.File.Exists(txtECOFile.Text) = True Then
xlApp.visible = False
xlApp.UserControl = False
xlWorkSheet = xlWorkBook.Worksheets("Sheet1")
'dsECODataSet = xlWorkSheet.ExportDataTable(xlWorkSheet.UsedRange, ExcelExportDataTableOptions.ColumnNames)
Next
Next
xlWorkBook.Close()
xlApp.Quit()
Message")
dsECODataSet.tables.Clear()
End If
Dim er AS String = TRIM(Ex.Message)
MyMessageBox(er, True, MsgBoxStyle.OKOnly, "Testing OleDB Connection string")
Finally
End Try
End Sub
Have you tried testing your code using another file? If it works, then there is an issue with the file you are using, which seems more likely to me, as your code looks like it should work.
> Dim rCnt As Integer
> Dim cCnt As Integer
> Dim Obj As Object
> Try
> Next
> Next
> xlWorkBook.Close()
> xlApp.Quit()
> Message")
> End If
> Finally
> End Try
> End Sub
I changed my open statement to 'xlWorkBook = xlApp.Workbooks._Open(txtECOFile.Text, 2, False, 5)' and it worked. All other lines of code has passed as well.
I don't know what the difference is but it works. Now I need to figure out how to get the excel data into a dataset.
Thanks for you help and time.
Dan
Sent: Tuesday, March 01, 2011 11:11 AM
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, Dan Godfrey <dgodfrey@...> wrote:
> Dim rCnt As Integer
> Dim cCnt As Integer
> Dim Obj As Object
> Try
> Next
> Next
> xlWorkBook.Close()
> xlApp.Quit()
> Message")
> End If
> Finally
> End Try
> End Sub
