9.05.605 Progress
Other software: Service Connect, Insite Manifest and APM+,
Corporate wants to move us to a new IP range. All PCs have already changed, and servers are next.
What problems will I run into?
9.05.605 Progress
So long as you’ve used DNS names for all references in your setup, there should be no issues except a clear break in communication requiring a full restart of Epicor and all clients. I’d check all the setup that you know about for hard-coded IP addresses. Make sure that during the cut-over you’re testing to make sure everything connects correctly, and if not, check configurations accordingly for IP addresses.
