Negative Inventory
>How does a job get finished, and its materials
>backflushed if you don't have the parts on hand
Things happening out of sequence.
It isn't as bad anymore.
Used to be common practice, left over from the previous system.
Assemblers see parts in the machine shop that are needed for their job and... take them, finish their job using them.
But... the child jobs weren't processed or inventory moved yet.
--- In vantage@yahoogroups.com, "c.krusen1" <ckrusen1@...> wrote:
> I understand your issue with costs and neg-QOH. We use precious metals in our products so the part costs are always fluctuating. So if a job "borrows" inventory before it is received, the job gets the "old" price (higher or lower), and the receipt generates a CST-ADJ to what's "on-hand" (the receipt qty minus the IOU qty).
> We don't currently track labor or operations, and hence don't do any backflushing. So I haven't experienced your issues regarding backlushing.
> Just out of curiousity... How does a job get finished, and its materials backflushed if you don't have the parts on hand?
> Calvin
> --- In vantage@yahoogroups.com, "cooner_55421" <cooner_55421@> wrote:
> > In our case it causes cost issues but...
> > It depended several other things in the job(s), auto-receive non-stock, average cost.
> > With the right combination and then parts backflush with a negative qty... it is a mess to clean it up and get the costs corrected.
> > --- In vantage@yahoogroups.com, "c.krusen1" <ckrusen1@> wrote:
> > > I'm not being snarky, But what's wrong with a negative QOH?
> > > A negative QOH really just means that some other transaction that increments the QOH hasn't happened yet, and that you "owe" inventory.
> > > In the ideal world you'd never get a neg-QOH, as you wouldn't issue/ship/scrap parts that you don't have. But since you'll undoubtedly need to issue material before its receipt is processed, you'll need to accumulate those "IOU's".
> > > If your just doing it to force people to do their job properly (i.e., to keep the receiver from sitting on receipts), then it's going to cause more problems, that will result in required work arounds.
> > > Who is willing to hold up an end of month shipment that needs to go, because, the packing slip for a few screws got lost.
> > > Calvin
> > > --- In vantage@yahoogroups.com, "tchristie1" <tchristie@> wrote:
> > > > I believe there is a place that I can check a box to prevent the company or plant from allowing negative OH balances. Is that correct or am I just dreaming?
> > > > We are on 9.05.606
> > > > Thanks,
> > > > Tom
We are on 9.05.606
Tom
I forget off the top of my head, but either Part Class or Product Group has the option to "allow, warn or stop" negative transactions. There's probably a company config as well?
Ken
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of tchristie1
Sent: Friday, August 26, 2011 3:23 PM
Subject: [Vantage] Negative Inventory
We are on 9.05.606
Tom
>Part Class
One "gotcha" I've run into.
(at least up to 8.03.409C, I haven't check E9).
Backflushing does not honor the Part Class settings and will still drive inventory negative.
We asked Epicor for a customization to prevent backflushing from driving inventory negative.
They came back about a week alter & said they wouldn't even quote it.
I can't remember
> Ken
> We are on 9.05.606
> Thanks,
> Tom
Seems like a really simple BPM, a data directive on partbin.o nhandqty < 0 raise exception.
Received: Friday, 26 Aug 2011, 4:17pm
To: vantage@yahoogroups.com [vantage@yahoogroups.com]
Subject: [Vantage] Re: Negative Inventory
>Part Class
I can't remember
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, Ken Williams <kwilliams@...> wrote:
> Ken
> From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of tchristie1
> We are on 9.05.606
> Thanks,
> Tom
Yes, you are probably correct - E9.
When I was trying to fix this, it was V8... no data directives.
> From: cooner_55421 [cooner_55421@...]
> >Part Class
> I can't remember
> --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, Ken Williams <kwilliams@> wrote:
> > Ken
> > We are on 9.05.606
> > Thanks,
> > Tom
Calvin
> We are on 9.05.606
> Thanks,
> Tom
part class has that, just found it the hard way today...
----- Original Message -----
Sent: Friday, August 26, 2011 5:24:21 PM
Subject: RE: [Vantage] Negative Inventory
Â
Ken
From: vantage@yahoogroups.com [mailto: vantage@yahoogroups.com ] On Behalf Of tchristie1
We are on 9.05.606
Tom
> Calvin
> > We are on 9.05.606
> > Thanks,
> > Tom
Calvin
> > Calvin
> > > We are on 9.05.606
> > > Thanks,
> > > Tom
The negative action stop or warn is held under each individual "Part Class
Maintenance".
Josh Serwe
Manager of Warehouse & Logistics
920.437.6400 Ext. 330
Safety
Professionalism
Effectiveness
Easy
Demand Results
<http://www.wisconsinconverting.com>
This e-mail, including attachments, may include confidential and/or
proprietary information, and may
be used only by the person or entity to which it is addressed. If the reader
of this e-mail is not the
intended recipient or his or her authorized agent, the reader is hereby
notified that any dissemination,
distribution or copying of this e-mail is prohibited. If you have received
this e-mail in error, please
notify the sender by replying to this message and delete this e-mail
immediately.
Calvin,
I don't see an issue with creating a negative on hand if the system is not
"real time" but in a "real time" system it should not happen. It let's you
know that there is an issue that needs to be addressed. If you allow these
transactions it snowballs into a bigger issue. I like to stop the problem
before it gets out of control.
Josh Serwe
Safety
Professionalism
Effectiveness
Easy
Demand Results
this e-mail in error, please u allow
immediately.
