Since you’re already using SubQuery criteria, you are able to use calculated fields in your expression. Create a calculated field that returns true, yes, etc. when you want to select that record and just use it to select your record.
I’m sorry, I don’t get it. I can see moving the subquery criteria out to the individual subqueries. You are suggesting to make another calculated field to filter the records we want. I am not sure what you mean.
If I am reading the criteria we have correctly, it should say:
labor type = S AND Hours > 0
OR
labor type = P and Mins > 0
AND
OpSeq <> 0
AND
ResGrp <> 10MB, 9, FP, MP
AND
JobClose >= 1/1/2010
Create a calculated field of type nvarchar(1) with the exact criteria above. If it validates to true, set it to “Y” else “N”.
In your subQuery Criteria, under tables choose Calculated Fields, then select your calculated field. Check if that field is equal to “Y”.
That makes sense! Is that a better way than what we have currently, or just a different way? Also this doesn’t really answer the request to have double parentheses, it just sidesteps the request. That is fine by me, I am just curious what is the best way?
IDK, having just one line in the criteria seems easier to enter and you can do some real complicated selection criteria that reads much easier in a calculated field. Double parenthesis are much easier and clearer in an expression than a subQuery criteria. ![]()
Then there’s this! Nice Mark.
Love learning this stuff. I can’t believe I’ve never needed this.
How did we miss that? I think it is because it isn’t obvious that you can type in there with the drop down! Awesome!!
It’s that way in classic too. I went to go test it, because if they missed that, I was gonna put in a ticket. But they didn’t.
also literally anything else.
And to think you don’t like widgets…
