New Currency Field not showing value
Hi
I have added a new currency field to a screen, and it refuses to show the value that is in the database. I have added a numeric field and bound it to the same field, and that shows the value as expected.
I have set the Active Currency Type to BASE, which is what is used on one of default currency fields. The only other property I have not set is ERP Binding Document do I need to set this? And if so, what do I set it to?
Or is there some dark art I haven’t learnt yet in working with Epicor Currency Fields.
Do you have another field e.g a tick box or combo box which is controlling the views. The currencybox requires multi binding into one control.
One to show the value
One to control what you’re seeing. USD, Base (Sterling), EUR
Let’s see the set up of your component.
