Hi There I’m new on this forum I’m learnig about epicor forms
so… I have been playing around 2 utragrids basically I’m passing rows from one to another
the second has binding , after several tries od add de row I just could adding to the datasource with this Code:
if(this.addedParts.Rows.Count == 0){
DataSet dataSet1 = new DataSet("dataSet1");
DataTable table = new DataTable("Table");
//Create three columns that will hold sample data.
DataColumn column1 = new DataColumn(“Part Number”, typeof(string));
DataColumn column2 = new DataColumn(“Customer Part Number”, typeof(string));
DataColumn column3 = new DataColumn(“Item Description”, typeof(string));
DataColumn column4 = new DataColumn(“Location”, typeof(string));
DataColumn column5 = new DataColumn(“Buyer/Planner”, typeof(string));
DataColumn column6 = new DataColumn(“Old Price”, typeof(decimal));
DataColumn column7 = new DataColumn(“New Price”, typeof(decimal));
//Add the columns to the table.
table.Columns.AddRange(new DataColumn[] { column1, column2, column3,column4, column5, column6,column7 });
//Add the table to the dataset.
dataSet1.Tables.Add(table);
this.addedParts.DataSource = dataSet1;
UltraGridRow row = this.addedParts.DisplayLayout.Bands[0].AddNew();
row.Cells[0].Value = rowSelected.Cells[0].Value;
row.Cells[1].Value = rowSelected.Cells[2].Value;;
row.Cells[2].Value = rowSelected.Cells[3].Value;
row.Cells[3].Value = "10";
row.Cells[4].Value = "Test Buyer";
row.Cells[5].Value = rowSelected.Cells[8].Value;
row.Cells[6].Value = 16.2;
the code works … but how can I tell the grid the Field names not just the caption for the columns for new rows , I mean the fields name that belongs to the main binding
