Another alternative would be to try a dashboard report. I've been able to put multiple BAQs in a dashboard and do the linking between the BAQ results tables in Crystal. That also allows me to use the same tables in different ways (as a summary and with detail), etc. (we're still on Vantage so I can't take advantage of multiple instances of the same table in a BAQ in Epicor 9). I can include only the BAQ tables I need when using subreports. I've found it to be very flexible.
Sue
Sue
--- In vantage@yahoogroups.com, Neil Buckman <nbuckman@...> wrote:
> Thanks Jim,
> I see the value of RDD in that it sends to Crystal a number of tables of data that can be used selectively in sub-reports, but the BAQ report sends just the one "Results" table.
> If I understand, what you are saying is that the new report will be a version of an existing one, but made "new" by the tables and formatting used. But to run it, you would still have to run the original report from the menu and choose the "new" style. Is that right?
> Neil Buckman
> Information Technology
> [Description: Gibson Shopfitters]
> DH Gibson Pty Ltd | 205-231 Fairfield Rd | YENNORA NSW 2161
> Office 8724 4600 | Direct 8724 4618 | Fax 8724 4604 | Mobile 0413 125 994
> nbuckman@...<mailto:nbuckman@...> | www.gibsonshopfitters.com.au <http://www.gibsonshopfitters.com.au/>
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of jckinneman
> Sent: Wednesday, 3 October 2012 11:34 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: New report from Report Data Maintenance
> Knowing how useful RDDs can be don't want to leave that impression. May be semantics but the RDD can be used to create any number of new reports. The base connections in a RDD frequently are the same base connections you might create using a BAQ. As long as you can figure out a path to the table you can link in new tables. It takes a little bit to figure out how the RDD tool works but once that is done you'll find it is pretty flexible.
> Both the BAQ and RDD generate XML, at that point it is up to the crystal report to format, organize and present the data. As long as the data you are looking for is in the XML, crystal doesn't care much how it gets to it.
> RDD is a tool and like any other tool not appropriate for all things but I'd encourage getting familiar with it.
> Jim Kinneman
> Encompass Solutions, Inc
> --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, Neil Buckman <nbuckman@<mailto:nbuckman@>> wrote:
> > Thanks for all the responses.
> > I guess the answer is simply that you can't create a new report from the Report Data Maintenance / Styles functions, only modify existing ones.
> > Oh well, back to the BAQ then ...
> > - Neil
> > From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of John Myers
> > Sent: Tuesday, 2 October 2012 11:33 PM
> > To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>
> > If you're talking about creating a new report, not duplicating and
> > modifying an existing report, that would be done thru the BAQ Report
> > Designer(Executive Analysis/Business Activity Management/General Operations
> > menu) after creating a BAQ for the report. The Actions menu has a Generate
> > Sample Data item to create an XML file for use in designing the Crystal
> > report. If you're modifying a duplicated RDD, then running the duplicated
> > report after modification should create the XML file with the modified data.
> > om
> > http://www.linkedin.com/in/buckeyefamilyone
> > Notice:This e-mail and any attachments are confidential and are only for the use of the person to whom they are addressed. If you are not the intended recipient please advise the sender by return e-mail and delete the message and any attachments. Any use, interference with, disclosure or copying of this message or any attachments is unauthorised and prohibited. The sender does not warrant that the information is free of a virus or any other defect or error, and any views expressed herein, unless specifically indicated otherwise, are those of the individual sender.
> > The DH Gibson Group of Companies - http://www.gibsonshopfitters.com.au
> > P Please consider our shared environment before printing this communication.
