No data Blank Title 67256
Karl, I didn't have to. Dale's response lays out a better solution without adding the table to the definition.
Ken
----- Original Message ----
Sent: Thursday, July 24, 2008 2:33:56 PM
Subject: Re: [Vantage] no data
Ken,
Did you establish the relationship of the Part table to OrderDtl in the report definition?
--- On Thu, 7/24/08, Ken Taylor <ktaylorv@yahoo. com> wrote:
Subject: [Vantage] no data
To: vantage@yahoogroups .com
Date: Thursday, July 24, 2008, 9:41 AM
To all Crystal gurus:
I'm attempting to modify the Order Acknowledgement with data from the Parts table UDF. I've added the table to the Report definition, created the new report style. In Crystal I can see the Parts table and add the fields to the report, however there is no data shown. The link is with PartNum from OrderDtl and Parts table as left outer join. All other data shows except the fields from Parts. Can anyone make suggestions? Thanks for your input.
Ken
Ken
First step is to determine where the problem is.
Is the data in the XML? If it is then it is a Crystal issue. If not
you have a Report Definition issue.
Did you define the outer join in both Report Definition and Crystal?
Dale
Of Ken Taylor
Sent: Thursday, July 24, 2008 11:41 AM
for your input.
Ken
Dale, I defined it in Crystal. Where exactly do you do it in the Report Definition? When I go there, there is absolutely no relationship established for any tables. Perhaps there is the missing link. There is other things I don't understand like Sequence control and OutputreportlanguageID.
Do I have to create a relationship? Thanks.
Ken
Sent: Thursday, July 24, 2008 9:57:12 AM
Subject: RE: [Vantage] no data
Dale
____________ _________ _________ __
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf
Of Ken Taylor
for your input.
Ken
Ken,
I am looking at a 8.03.4xx system so some thing may be different for
you..
I am looking at the Order Acknowledgment in the in the Report Data
Maint. In this case, you do not need to add the Part table.
If you go to the Linked Tables tab --> Description Fields tab. In the
drop down box choose PartNum. This will list the Fields
available and the Fields picked. Move over the UDF you want into
picked. After doing a print generate/Preview you should see your new
fields
in the XML.
In CR Developer, open the report, set the datasource location to your
new XML. I think the new fields will be called something like
Part_Character01.
Add the fields to you report and test.
If all is well I think you can delete the Part table out of the report
Data Definition and the Crystal Report.
If you do need to add a table, then you do need to define the
relationship in Report Data Maint. There is a tab to do this.
Dale
Of Ken Taylor
Sent: Thursday, July 24, 2008 12:10 PM
Ken
<mailto:dale.schuerman%40ramsys.com> >
Dale
Behalf
Of Ken Taylor
for your input.
Ken
Dale, you are a lifesaver. That did the trick. You don't happen to know where I can get documentation on programming and customizing screens or BPMs outside of training.
Again. Thanks for all the help.
Ken
Sent: Thursday, July 24, 2008 10:53:27 AM
Ken,
you..
fields
in the XML.
Part_Character01.
Dale
Of Ken Taylor
Outputreportlanguag eID.
Ken
<mailto:dale. schuerman% 40ramsys. com> >
To: vantage@yahoogroups .com <mailto:vantage% 40yahoogroups. com>
Dale
From: vantage@yahoogroups .com [mailto:vantage@ yahoogroups .com] On
Behalf
Of Ken Taylor
for your input.
Ken
Ken,
EpicWeb has some articles and examples, help has some examples, and this
yahoo group.
Perspectives is in October and they will have sessions on a lot of these
topics.
Epicor has published the "Epicor Tools User Guide". It has some
information and some of it you just have to learn thru experimenting.
Dale
Of Ken Taylor
Sent: Thursday, July 24, 2008 1:46 PM
Ken
Ken,
you..
fields
in the XML.
Part_Character01.
Dale
Behalf
Of Ken Taylor
Ken
Dale
Behalf
Of Ken Taylor
for your input.
Ken
Ken,
Ken
