No workflow step?
When opening the invoice, there is no workflow step, and the option to restart the workflow is disabled.
How to resolve this?
You will have to manually assign it to a workflow. If you would like this to be automated, you need to add a default workflow into the Content Type.
If it is already in a workflow, then you may just need to drag up the Workflow tab from below the Content Fields tab.
Is the invoice posted in Kinetic?
How did this document get into DocStar?
