Situation
We have a customized MTLTag Report that we use as nonconformance tags. We just noticed that if a reason code is entered during the Inspection Processing step it is not reflected back in the non-conformance table. We can also see that if we open up DMR Tracker under the History tab we can see the corrected reason code.
Thought Process/Execution
I would like to be able to reference that reason code onto our nonconformance tags if it exists. The issue is that this field is an EpiBinding:
What I need
How would I track the EpiBinding back to a field I can actually use and reference it within our tag?
