Not getting PO Suggestion for purchase part
We have a fair amount of backlog that is past due because of the inability to get material and we wanted to allow the system to show when something should have been started even if it was in the past - if that makes sense.
I could try that in the morning after the MRP run overnight. What version are you on?
Hi Brandon/Wendy,
I have seen days of supply do interesting things especially with long lead parts. Wendy I would experiment with pushing that DOS out past the lead time to see the effect, perhaps set it at 100 and see if you get expected suggestions.
Nancy
Thanks! I’ll try that!
I swear Epicor has picked this week to see if it can break me…
Is Consolidated Purchasing selected in error - we had this on parts and MRP would look at them
  • wouldn’t
Nope…no consolidate purchasing…
On the Part’s Part Class?
Nope…I double checked. And it seems to be the only part that is currently causing trouble…
I’m not sure as to why you have Urgent planning filled in with the exact same information as the normal purchasing criteria on the Site\Detail tab in Part Maintenance. Urgent planning should only be filled in when there’s an alternative option for when lead time from your normal supplier is insufficient.
Try deleting out all of the Urgent Planning details, as it could be confusing MRP.
On the main tab of Part Maintenance, make sure it’s set as “Type = Purchased” as people can change one and click “No” on the popup that asks if the Part and PartPlant records should be synced.
When scheduling MRP to automatically run, ALWAYS check the Dynamic checkboxes for both Cut Off Date and Schedule Start Date. Hard set dates are ONLY for manually processing MRP.
The 20 Days of Supply should result in 3 Purchase Suggestions. Make sure that the Method for the Manufactured Part doesn’t have the Material Part checked as View As Assembly, Pull As Assembly, or Plan As Assembly. (Just covering all of the bases of possible issues).
After that, compare this part setup with the setup of another part that is generating suggestions, just to see if there is anything set differently between the two. Check every tab thoroughly.
As a last ditch effort, set the part to Type = Manufactured on the main Part\Detail tab (and select Yes or OK to the popup window), Save. Then set the part back to Type = Purchased (Click Yes or OK again for the popup window), and save again. Then see what happens the next time MRP runs.
IM running into the same thing I cannot get the PO suggestion or change PO suggestion to update. I have created large then normal demand to make sure it picks up new requirements. When I run Time Phase it does show all the MRP runs, SO, and existing PO but no new ones.
Did you check Part Maintenance >Sites tab to make sure that the “Generate PO Suggestions” box is checked. Also, if the part has a Rev that isn’t approved or the job creating the demand is not engineered, the PO Suggestions will be affected by that as well.
Check the Po generation logs to see if the part is referenced at all or the system does not see the demand.
Are you running MRP recalc needed before your generation runs?
We have seen this occasionally where the record in the PartDtl table for a sales order release is out of sync with the orderrel table. Specifically, the PartDtl record had FirmRelease = FALSE, but OrderRel has FirmRelease=TRUE.
Suggestions won’t generate for Un Firm releases, so PartDtl was the problem.
We just had to unfirm/firm the release on Order Entry and the issue resolved.
