<div id="ygrps-yiv-974648441yiv9965510233ygrp-text">
<div class="ygrps-yiv-974648441yiv9965510233WordSection1"><div class="ygrps-yiv-974648441yiv9965510233MsoNormal">Hi – I am very late to Epicor 9.05, but we are now in a huge time-crunch to get it upgraded due to a requirement from our parent company that all of our PC’s must be windows 7 before April 8.</div><div class="ygrps-yiv-974648441yiv9965510233MsoNormal"> </div><div class="ygrps-yiv-974648441yiv9965510233MsoNormal">Anyway, long story short, the one big hang up we are having is that all of our reporting from Vantage 5.2 was using MS Access connecting via ODBC. I knew there would be a lot of conversion required to get this working on Epicor 9.05, however I did not anticipated all of the issues we are having just getting ODBC working. I have tried searching this group as well as other knowledge bases and the workarounds I have come across are not working. </div><div class="ygrps-yiv-974648441yiv9965510233MsoNormal"> </div><div class="ygrps-yiv-974648441yiv9965510233MsoNormal">So, I was hoping someone on this group has
successfully gotten ODBC working to connect to the Epicor 9.05 Progress data using MS Access 2010 32-bit on a 64-bit OS?
be beyond appreciative!
This email may contain material that is confidential, privileged and/or attorney work product for the sole use of the intended recipient. Any review, reliance or distribution by others or forwarding without express permission is strictly prohibited. If you are not the intended recipient, please contact the sender and delete all copies.
__________________________________________________________________________
</div>
<div style="color:#fff;height:0;"></div></div>
#ygrps-yiv-974648441 #ygrps-yiv-974648441yiv9965510233 #ygrps-yiv-974648441yiv9965510233ygrp-mkp hr {
border:1px solid #d8d8d8;}
#ygrps-yiv-974648441 #ygrps-yiv-974648441yiv9965510233 #ygrps-yiv-974648441yiv9965510233ygrp-mkp #ygrps-yiv-974648441yiv9965510233hd {
color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;}
#ygrps-yiv-974648441 #ygrps-yiv-974648441yiv9965510233 #ygrps-yiv-974648441yiv9965510233ygrp-mkp #ygrps-yiv-974648441yiv9965510233ads {
margin-bottom:10px;}
#ygrps-yiv-974648441 #ygrps-yiv-974648441yiv9965510233 #ygrps-yiv-974648441yiv9965510233ygrp-mkp .ygrps-yiv-974648441yiv9965510233ad {
padding:0 0;}
#ygrps-yiv-974648441 #ygrps-yiv-974648441yiv9965510233 #ygrps-yiv-974648441yiv9965510233ygrp-mkp .ygrps-yiv-974648441yiv9965510233ad p {
margin:0;}
#ygrps-yiv-974648441 #ygrps-yiv-974648441yiv9965510233 #ygrps-yiv-974648441yiv9965510233ygrp-mkp .ygrps-yiv-974648441yiv9965510233ad a {
color:#0000ff;text-decoration:none;}
#ygrps-yiv-974648441 #ygrps-yiv-974648441yiv9965510233 #ygrps-yiv-974648441yiv9965510233ygrp-sponsor #ygrps-yiv-974648441yiv9965510233ygrp-lc {
font-family:Arial;}
#ygrps-yiv-974648441 #ygrps-yiv-974648441yiv9965510233 #ygrps-yiv-974648441yiv9965510233ygrp-sponsor #ygrps-yiv-974648441yiv9965510233ygrp-lc #ygrps-yiv-974648441yiv9965510233hd {
margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;}
#ygrps-yiv-974648441 #ygrps-yiv-974648441yiv9965510233 #ygrps-yiv-974648441yiv9965510233ygrp-sponsor #ygrps-yiv-974648441yiv9965510233ygrp-lc .ygrps-yiv-974648441yiv9965510233ad {
margin-bottom:10px;padding:0 0;}
#ygrps-yiv-974648441 #ygrps-yiv-974648441yiv9965510233 #ygrps-yiv-974648441yiv9965510233actions {
font-family:Verdana;font-size:11px;padding:10px 0;}
#ygrps-yiv-974648441 #ygrps-yiv-974648441yiv9965510233 #ygrps-yiv-974648441yiv9965510233activity {
background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;}
#ygrps-yiv-974648441 #ygrps-yiv-974648441yiv9965510233 #ygrps-yiv-974648441yiv9965510233activity span {
font-weight:700;}
#ygrps-yiv-974648441 #ygrps-yiv-974648441yiv9965510233 #ygrps-yiv-974648441yiv9965510233activity span:first-child {
text-transform:uppercase;}
#ygrps-yiv-974648441 #ygrps-yiv-974648441yiv9965510233 #ygrps-yiv-974648441yiv9965510233activity span a {
color:#5085b6;text-decoration:none;}
#ygrps-yiv-974648441 #ygrps-yiv-974648441yiv9965510233 #ygrps-yiv-974648441yiv9965510233activity span span {
color:#ff7900;}
#ygrps-yiv-974648441 #ygrps-yiv-974648441yiv9965510233 #ygrps-yiv-974648441yiv9965510233activity span .ygrps-yiv-974648441yiv9965510233underline {
text-decoration:underline;}
#ygrps-yiv-974648441 #ygrps-yiv-974648441yiv9965510233 .ygrps-yiv-974648441yiv9965510233attach {
clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;}
#ygrps-yiv-974648441 #ygrps-yiv-974648441yiv9965510233 .ygrps-yiv-974648441yiv9965510233attach div a {
#ygrps-yiv-974648441 #ygrps-yiv-974648441yiv9965510233 .ygrps-yiv-974648441yiv9965510233attach img {
border:none;padding-right:5px;}
#ygrps-yiv-974648441 #ygrps-yiv-974648441yiv9965510233 .ygrps-yiv-974648441yiv9965510233attach label {
display:block;margin-bottom:5px;}
#ygrps-yiv-974648441 #ygrps-yiv-974648441yiv9965510233 .ygrps-yiv-974648441yiv9965510233attach label a {
#ygrps-yiv-974648441 #ygrps-yiv-974648441yiv9965510233 blockquote {
margin:0 0 0 4px;}
#ygrps-yiv-974648441 #ygrps-yiv-974648441yiv9965510233 .ygrps-yiv-974648441yiv9965510233bold {
font-family:Arial;font-size:13px;font-weight:700;}
#ygrps-yiv-974648441 #ygrps-yiv-974648441yiv9965510233 .ygrps-yiv-974648441yiv9965510233bold a {
#ygrps-yiv-974648441 #ygrps-yiv-974648441yiv9965510233 dd.ygrps-yiv-974648441yiv9965510233last p a {
font-family:Verdana;font-weight:700;}
#ygrps-yiv-974648441 #ygrps-yiv-974648441yiv9965510233 dd.ygrps-yiv-974648441yiv9965510233last p span {
margin-right:10px;font-family:Verdana;font-weight:700;}
#ygrps-yiv-974648441 #ygrps-yiv-974648441yiv9965510233 dd.ygrps-yiv-974648441yiv9965510233last p span.ygrps-yiv-974648441yiv9965510233yshortcuts {
margin-right:0;}
#ygrps-yiv-974648441 #ygrps-yiv-974648441yiv9965510233 div.ygrps-yiv-974648441yiv9965510233attach-table div div a {
#ygrps-yiv-974648441 #ygrps-yiv-974648441yiv9965510233 div.ygrps-yiv-974648441yiv9965510233attach-table {
width:400px;}
#ygrps-yiv-974648441 #ygrps-yiv-974648441yiv9965510233 div.ygrps-yiv-974648441yiv9965510233file-title a, #ygrps-yiv-974648441 #ygrps-yiv-974648441yiv9965510233 div.ygrps-yiv-974648441yiv9965510233file-title a:active, #ygrps-yiv-974648441 #ygrps-yiv-974648441yiv9965510233 div.ygrps-yiv-974648441yiv9965510233file-title a:hover, #ygrps-yiv-974648441 #ygrps-yiv-974648441yiv9965510233 div.ygrps-yiv-974648441yiv9965510233file-title a:visited {
#ygrps-yiv-974648441 #ygrps-yiv-974648441yiv9965510233 div.ygrps-yiv-974648441yiv9965510233photo-title a, #ygrps-yiv-974648441 #ygrps-yiv-974648441yiv9965510233 div.ygrps-yiv-974648441yiv9965510233photo-title a:active, #ygrps-yiv-974648441 #ygrps-yiv-974648441yiv9965510233 div.ygrps-yiv-974648441yiv9965510233photo-title a:hover, #ygrps-yiv-974648441 #ygrps-yiv-974648441yiv9965510233 div.ygrps-yiv-974648441yiv9965510233photo-title a:visited {
#ygrps-yiv-974648441 #ygrps-yiv-974648441yiv9965510233 div#ygrps-yiv-974648441yiv9965510233ygrp-mlmsg #ygrps-yiv-974648441yiv9965510233ygrp-msg p a span.ygrps-yiv-974648441yiv9965510233yshortcuts {
font-family:Verdana;font-size:10px;font-weight:normal;}
#ygrps-yiv-974648441 #ygrps-yiv-974648441yiv9965510233 .ygrps-yiv-974648441yiv9965510233green {
color:#628c2a;}
#ygrps-yiv-974648441 #ygrps-yiv-974648441yiv9965510233 .ygrps-yiv-974648441yiv9965510233MsoNormal {
margin:0 0 0 0;}
#ygrps-yiv-974648441 #ygrps-yiv-974648441yiv9965510233 o {
font-size:0;}
#ygrps-yiv-974648441 #ygrps-yiv-974648441yiv9965510233 #ygrps-yiv-974648441yiv9965510233photos div {
float:left;width:72px;}
#ygrps-yiv-974648441 #ygrps-yiv-974648441yiv9965510233 #ygrps-yiv-974648441yiv9965510233photos div div {
border:1px solid #666666;height:62px;overflow:hidden;width:62px;}
#ygrps-yiv-974648441 #ygrps-yiv-974648441yiv9965510233 #ygrps-yiv-974648441yiv9965510233photos div label {
color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;}
#ygrps-yiv-974648441 #ygrps-yiv-974648441yiv9965510233 #ygrps-yiv-974648441yiv9965510233reco-category {
font-size:77%;}
#ygrps-yiv-974648441 #ygrps-yiv-974648441yiv9965510233 #ygrps-yiv-974648441yiv9965510233reco-desc {
font-size:77%;}
#ygrps-yiv-974648441 #ygrps-yiv-974648441yiv9965510233 .ygrps-yiv-974648441yiv9965510233replbq {
margin:4px;}
#ygrps-yiv-974648441 #ygrps-yiv-974648441yiv9965510233 #ygrps-yiv-974648441yiv9965510233ygrp-actbar div a:first-child {
margin-right:2px;padding-right:5px;}
#ygrps-yiv-974648441 #ygrps-yiv-974648441yiv9965510233 #ygrps-yiv-974648441yiv9965510233ygrp-mlmsg {
font-size:13px;font-family:Arial, helvetica, clean, sans-serif;}
#ygrps-yiv-974648441 #ygrps-yiv-974648441yiv9965510233 #ygrps-yiv-974648441yiv9965510233ygrp-mlmsg table {
font-size:inherit;font:100%;}
#ygrps-yiv-974648441 #ygrps-yiv-974648441yiv9965510233 #ygrps-yiv-974648441yiv9965510233ygrp-mlmsg select, #ygrps-yiv-974648441 #ygrps-yiv-974648441yiv9965510233 input, #ygrps-yiv-974648441 #ygrps-yiv-974648441yiv9965510233 textarea {
font:99% Arial, Helvetica, clean, sans-serif;}
#ygrps-yiv-974648441 #ygrps-yiv-974648441yiv9965510233 #ygrps-yiv-974648441yiv9965510233ygrp-mlmsg pre, #ygrps-yiv-974648441 #ygrps-yiv-974648441yiv9965510233 code {
font:115% monospace;}
#ygrps-yiv-974648441 #ygrps-yiv-974648441yiv9965510233 #ygrps-yiv-974648441yiv9965510233ygrp-mlmsg * {
line-height:1.22em;}
#ygrps-yiv-974648441 #ygrps-yiv-974648441yiv9965510233 #ygrps-yiv-974648441yiv9965510233ygrp-mlmsg #ygrps-yiv-974648441yiv9965510233logo {
padding-bottom:10px;}
#ygrps-yiv-974648441 #ygrps-yiv-974648441yiv9965510233 #ygrps-yiv-974648441yiv9965510233ygrp-msg p a {
font-family:Verdana;}
#ygrps-yiv-974648441 #ygrps-yiv-974648441yiv9965510233 #ygrps-yiv-974648441yiv9965510233ygrp-msg p#ygrps-yiv-974648441yiv9965510233attach-count span {
color:#1E66AE;font-weight:700;}
#ygrps-yiv-974648441 #ygrps-yiv-974648441yiv9965510233 #ygrps-yiv-974648441yiv9965510233ygrp-reco #ygrps-yiv-974648441yiv9965510233reco-head {
color:#ff7900;font-weight:700;}
#ygrps-yiv-974648441 #ygrps-yiv-974648441yiv9965510233 #ygrps-yiv-974648441yiv9965510233ygrp-reco {
margin-bottom:20px;padding:0px;}
#ygrps-yiv-974648441 #ygrps-yiv-974648441yiv9965510233 #ygrps-yiv-974648441yiv9965510233ygrp-sponsor #ygrps-yiv-974648441yiv9965510233ov li a {
font-size:130%;text-decoration:none;}
#ygrps-yiv-974648441 #ygrps-yiv-974648441yiv9965510233 #ygrps-yiv-974648441yiv9965510233ygrp-sponsor #ygrps-yiv-974648441yiv9965510233ov li {
font-size:77%;list-style-type:square;padding:6px 0;}
#ygrps-yiv-974648441 #ygrps-yiv-974648441yiv9965510233 #ygrps-yiv-974648441yiv9965510233ygrp-sponsor #ygrps-yiv-974648441yiv9965510233ov ul {
margin:0;padding:0 0 0 8px;}
#ygrps-yiv-974648441 #ygrps-yiv-974648441yiv9965510233 #ygrps-yiv-974648441yiv9965510233ygrp-text {
font-family:Georgia;}
#ygrps-yiv-974648441 #ygrps-yiv-974648441yiv9965510233 #ygrps-yiv-974648441yiv9965510233ygrp-text p {
margin:0 0 1em 0;}
#ygrps-yiv-974648441 #ygrps-yiv-974648441yiv9965510233 #ygrps-yiv-974648441yiv9965510233ygrp-text tt {
font-size:120%;}
#ygrps-yiv-974648441 #ygrps-yiv-974648441yiv9965510233 #ygrps-yiv-974648441yiv9965510233ygrp-vital ul li:last-child {
border-right:none !important;}
