It looks like to me you are using the incorrect driver, unless you meant to use the DB2 version of the driver.
When you go to create the DSN, select the "Progress OpenEdge <version> Driver" listed below the ones that start with "OpenEdge" and end with "for DB2", "for MS SQL", and "for Sybase".
--- In vantage@yahoogroups.com, "Ellen Lensing" <ellen.lensing@...> wrote:
> Trying to set up a ODBC connection on my pc. I get as far as a test
> connect, then I get the message
> DATA DIRECT [ODBC DB2 WIRE PROTOCOL DRIVER] Socket Closed
> Anyone with help on this??
> Thanks
> Ellen
