Erik:
You wouldn't by any chance have the both progress 8 and 9 clients loaded on
the workstations, do you. If so, I suggest you uninstall the version 8 and
see what happens.
Terry L. Williams I.S. Manager Chipsco, Inc. 9936 Liberty St. Ext.
Meadville, PA 16335
p.814-333-6331 x236 f.814-337-2548 c.814-671-8650 tlw@...
<mailto:tlw@...> www.chipsco.com <http://www.chipsco.com/>
Sent: Thursday, June 20, 2002 12:38 PM
Subject: Re: [Vantage] Re: Odd Win98 Behavior after Patch .350 Install
Sorry Erik. IE 5.5 was just a guess. I've never seen that problem,
although we are on 5.1 patch .125. We have mostly Win98 workstations. Maybe
check with Epicor to see if there is a known issue with that patch.
Troy Funte
Liberty Electronics
see what happens.
Meadville, PA 16335
Troy Funte
Liberty Electronics
----- Original Message -----
Sent: Thursday, June 20, 2002 12:28 PM
Subject: [Vantage] Re: Odd Win98 Behavior after Patch .350 Install
Troy,
All of our workstations are running at least IE5.5 and some are
running 6.0. I ran FileMon during the lockup and OLE32.dll is the
last file accessed. I'm not sure if it is getting stuck there or not.
I've tried replacing the file with older versions and the Win98
install original, but it did not work any better. Any other ideas???
Erik
--- In vantage@y..., "Troy Funte" <tfunte@e...> wrote:
> Try upgrading to Internet Explorer 5.5 on one of the Win98
workstations and see what happens.
> Troy Funte
> Liberty Electronics
> From: erikrs301
> To: vantage@y...
> Sent: Wednesday, June 19, 2002 11:30 AM
> Subject: [Vantage] Odd Win98 Behavior after Patch .350 Install
> Since patch .350 has been applied to Vantage 5.0 on our system,
we
> have been experiencing a couple problems with Win98. If Vantage
is
> open on a workstation and we want to open the Printers Folder, it
> will not open up until the Vantage session has been closed. If
> Vantage is minimized and we try to open the Printer's Folder,
Vantage
> can only be brought back up by hitting ALT+TAB, a mouse clik will
not
> work.
> We are running 3.0 Live and testing 5.0. The problem only occurs
on
> systems where both 3.0 and 5.0 clients are installed. It occurs
in
> both 3.0 and 5.0 on these workstations since patch .350 was
applied
> to Vantage 5.0. The datbases are on seperate servers and seperate
> mapped drives. We are using networked HP laser printers and some
> local printers. Any ideas as that what's going on here?
> Thanks!
> Erik Smalley
> IT Manager
> MEI
must have already linked your email address to a yahoo id to enable
access. )
Builder and Crystal Reports and other 'goodies', please goto:
> Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service.
