[Off Topic] Crystal Reports - formula with memo fie ld
Sarah,
You will find SQL expressions under "Insert" "Field Object". "SQL
expression Fields:" is located just below "Formula Fields:"
Jim Stetter
From: sarah.vareschi@... [mailto:sarah.vareschi@...]
Sent: Tuesday, March 26, 2002 12:29 PM
Subject: RE: [Vantage] [Off Topic] Crystal Reports - formula with memo fie
ld
Thanks for posting your solution. This sounds like the best one, since I
wouldn't have to change anything in the db. However, I can't find the
'Create SQL Expression' function on the 'insert' menu (or anywhere else)
in
crystal. I'm not sure why, I am on crystal 8.5.0.217. What version are
you
using?
Tech Support has a document that tells you how to change the actual field
size in the database from 1000 down to 250. Crystal will recognize a memo
field for a formula if its under 250. We tried this and it works very well.
The only thing to remember is if you change the size of a field and you run
the IDXBUILD it will reset the field size back to 1000. Just remember to
change it back to 250 again if you run IDXBUILD.
Sue Howard
Information Specialist
Image National, Inc.
sueh@... <mailto:sueh@...>
Sent: Tuesday, March 26, 2002 8:28 AM
Subject: [Vantage] [Off Topic] Crystal Reports - formula with memo field
I'm trying to use a 'memo' field (orderdtl.linedesc) in a formula in crystal
reports and it won't let me use it. Has anyone found a way around this?
Yahoo! Groups Sponsor
ADVERTISEMENT
<http://rd.yahoo.com/M=219350.1849043.3355872.1269402/D=egroupweb/S=17050071
83:HM/A=935585/R=0/*http://www.gotomypc.com/u/tr/yh/grp/300_1b/g22lp?Target=
mm/g22lp.tmpl>
<http://us.adserver.yahoo.com/l?M=219350.1849043.3355872.1269402/D=egroupmai
l/S=1705007183:HM/A=935585/rand=569371078>
All credit for this goes to Anton Wilson for posting this fix for this
particular problem.
To those of you who use Crystal with ODBC, and have hit the problem of
Crystal being unable to use a field of over 255 characters (memo or blob
field) in a formula, I have discovered 2 good solutions.
1 - I discovered this today, and it was right in front of my nose all along.
It's by far the simplest solution and I'd recommend it.
Go into the "Insert" menu in Crystal. Select "Create SQL Expression". From
here you can either do an RTrim, or more safely, do a "{fn
SUBSTRING((field.name),1,255)}" - this ensures that the field is no longer
than 255 characters.
From there you can include the SQL expression in formulas.
2 - The second option is to edit the length of the field in question,
directly in the Progress database.
I recommend doing a search on Epicor's ERAnet for "memo fields" or some such
search string, to locate their instructions on this.
But for your information you will need to edit the Vantage session file
(vantage.vtg) according to those instructions and save the modified version
as a different file.
Create yourself a shortcut (and make sure only the right person has access
to it!) and run the program. This gets you into the database and you can
change the format of any field in Vantage.
In all honesty I'm not sure that this is necessary though. Using an SQL
Expression in Crystal is a much cleaner, safer solution.
Hope that helps!
Anton Wilson,
Systems Analyst,
Deanestor Healthcare
Ted Kitch
ted@...
Sent: Tuesday, March 26, 2002 9:28 AM
ADVERTISEMENT
83:HM/A=935585/R=0/*http:/www.gotomypc.com/u/tr/yh/grp/300_1b/g22lp?Target=m
m/g22lp.tmpl>
<http://docs.yahoo.com/info/terms/> Terms of Service.
I think my problem is because I am not using ODBC, but rather just modifying
the Vantage Sales Order form using the dbf's. I have tried unsuccessfully
to search ePortal for the document on changing the field size and have
placed a call with tech support and am awaiting feedback.
Thanks for all the help.
Unfortunately, from my trials today, I found that neither of these
suggestions will work when modifying a form that uses the dbf's (not thru
ODBC). If anybody has found another way around this that would work with
modifying standard forms that use dbf's, I would love to hear it.
Sarah not sure of what your trying to do. This looks like a pretty involved
solution that might work. I have not played with it.
http://support.crystaldecisions.com/library/kbase/articles/c2007285.asp
<http://support.crystaldecisions.com/library/kbase/articles/c2007285.asp>
Good Luck
Dan Shallbetter
States Electric Mfg.
Sent: Tuesday, March 26, 2002 2:13 PM
ld
'Create SQL Expression' function on the 'insert' menu (or anywhere else) in
crystal. I'm not sure why, I am on crystal 8.5.0.217. What version are you
using?
