I implemented Exchange via RPC over HTTP using ISA at my last job. It
was tricky, but we got it done and it was a HUGE help migrating external
users from POP/SMTP to Exchange. It also let them synchronize their
handheld devices with their local computers (for those whose devices
didn't have the capability to sync via cellular-Internet) and get their
data into Exchange so they *could* use the OWA interface if they wanted
to.
Implementing Exchange via RPC/HTTP doesn't mean you cannot also
implement OWA; it's great to have both (for the reason stated above,
among others). If you want to quickly implement just OWA, you can set
it using HTTP only and not require HTTPS, meaning you don't need to buy
a signed certificate. If people like it, make the investment in the
cert, switch to HTTPS, and then you can enable forms-based
authentication, which will give you a (customizable) interface for
entering credentials, instead of using the boring/bland standard gray
Windows authentication pop-up box.
ISA server makes publishing the OWA site pretty straight-forward - it's
almost as easy as clicking "Next" a few times and it's done.
--Ari
Of clark_scott_l
Sent: Wednesday, September 03, 2008 9:02 AM
Subject: [Vantage] Re: Off Topic - Enabling Outside Access to email
You have another option if your users are permanently outside your
network. Exchange 2003/Outlook 2003 and above allow a setup called
HTTPS or RPC. This is a means to allow the users to run the full
Outlook client without a VPN connection. You would want an Exchange
consultant to set it up and leave you with directions for the client
setup, but this is working very well for our 400+ users.
Scott Clark
IT Manager
Wastequip, Inc.
to.
--Ari
Of clark_scott_l
Scott Clark
IT Manager
Wastequip, Inc.
>our
> I currently have a 2003 SBS server I want to enable access to for
> sales staff to get their email. I am using OWA w/Exchange 2003.The
> server has ISA 2000 running on it as well. I think I have enabledall
> the settings on the server side to allow this but I can't seem tofind
> any information on what needs to be done to allow access fromoutside my
> network. What do I need to do at the firewall (linksys VPNrouter)? I
> have enabled forwarding from port 443 to my server ip. What doesmy ISP
> need to do? Is this relatively secure doing it this way?[Non-text portions of this message have been removed]
> Thanks,
> Darren Mann
> IT Manager
> Miller Products Co.
> 1015 N. Main St.
> Osceola, IA 50213
> Ph. 641-342-2103
> Fax 641-342-3222
