That worked ... Thanks Ted
Sent: Thursday, January 04, 2001 11:17 AM
To: vantage@egroups.com
Subject: Re: [Vantage] Off Topic - VB
You can run regsvr32.exe from a command line. Just type regsvr32 and it
will show you the options. I've used this to register DLL's from batch
files.
HTH,
Ted Kitch
ted@...
files.
HTH,
Ted Kitch
ted@...
----- Original Message -----
To: 'vantage@egroups.com'
Sent: Thursday, January 04, 2001 11:02 AM
Subject: [Vantage] Off Topic - VB
This is an off topic request to the VB gurus out there ...
I have a logon script setup that copies 8 required DLL's from our server
to
client pc's to support a VB app. It also copies a shortcut to the user's
desktop to the VB executable on my server.
Problem is that the DLL's are not registered on the client PCs by simply
copying them down.
How can I copy and register a set of DLL's from within a logon script ?
Note that I do not want to run a "Setup" exe at each desktop --- 100 pc's
4 sites - 3 states - 2 IS people ....
Yes, I know zip about installing VB app's over a network ...
Thanks for the help,
Todd Anderson
J. Rubin & Co.
eGroups Sponsor
<http://www.egroups.com/files/vantage/>
(Note: If this link does not work for you the first time you try it, go
to www.egroups.com, login and be sure to save your password, choose My
Groups, choose Vantage, then choose Files. If you save the password, the
link above will work the next time you try it.)
eGroups Sponsor
<http://rd.yahoo.com/M=114382.818028.2619452.2/D=egroupmail/S=1700007183:N/A
=401181/*http://ad.doubleclick.net/jump/N1146.yahoo/B22751;sz=468x60;ord=978
628516?> Create your family tree at MyFamily.com!
