Most of what I learned came from this Group anyway. I'm just glad I
could pass some of it on.
--- In vantage@yahoogroups.com, Ahmet Erispaha <ahmeterispaha@...>
wrote:
>UD03.Update and the following query:
> Hi Nigel,
> Â
> Thanks for your response.
> Â
> I tested this further with a pre-processing directive on
> Â(ttUD03.Key1 = Part.ShortChar01 and ttUD03.Company=Part.Company)
> for each ttUD03 where (ttUD03.RowMod = 'D') each Part where
> ÂUD03 and Part Tables?
> It works!
> Â
> Thanks again for steering me in the right (BPM)Â direction.
> Â
> Ahmet Â
> --- On Tue, 11/11/08, Nigel Kerley <nigel.kerley@...> wrote:
> From: Nigel Kerley <nigel.kerley@...>
> Subject: [Vantage] Re: OK to set up foreign key constraint between
> To: vantage@yahoogroups.comand
> Date: Tuesday, November 11, 2008, 10:58 AM
> Hi Ahmet.
> Just tried it myself and you're right. You can leave the "tt" out
> Vantage recognises the table. I got this query accepted:an
> for each UD03, each Part where (UD03.Company = Part.Company) and
> (UD03.Key1 = Part.shortChar01)
> However, even if you get this working, I'm not sure that the BPM is
> getting actioned at all. I left out the conditions and just put in
> Action to display an informational message. I then went to the UD<ahmeterispaha@ ...>
> screen and deleted previouly entered data and it deleted with NO
> message!
> I've found this with a number of BOs, it seems some directives just
> don't cause BPMs to be actioned.
> Sorry I can't be more help.
> Anyone else have an idea?
> Nigel.
> --- In vantage@yahoogroups .com, Ahmet Erispaha
> wrote:between
> > Thanks for the suggestion, Nigel.Â
> > Â
> > A BPM sounds like a great idea, however I'm having some
> trouble setting up the pre-processing directive.Â
> > Â
> > Here's what I have:
> > Condition:Â number of rows in the designed query is not less than 1
> > Query: for each ttUD03 where (ttUD03.RowMod = 'D') each
> ttUD03.Key1= Part.ShortChar01
> > Â
> > Vantage doesn't seem to recognize ttUD03 in the "Compose Query"
> window -- it doesn't color code tha table name. Then when I click
> the "Check Query" button, I get an "Unable to find any table in the
> query" Parsing Error.
> > Â
> > Where am I going wrong?
> > Â
> > Thx,
> > Â
> > Ahmet
> > inde.com> wrote:
> > From: Nigel Kerley <nigel.kerley@ ...>
> UD03 and Part Tables?to
> > To: vantage@yahoogroups .com
> > Date: Tuesday, November 11, 2008, 4:14 AM
> > I haven't done any customisations like you've described, but a
> > possible solution to your problem would be to put a BPM in place
> > check if the category is being referenced before allowing it tobe
> > deleted.(so
> > I suspect you would create a Pre-Processing directive against the
> > UD03.DeleteByID BO.
> > HTH,
> > Nigel.
> > wrote:
> > > I'm working on a customization that provides a way for our
> > engineering folks to categorize parts according to their needs
> > that they can report on them or assign necessary changes to partsCategoryId,
> as
> > a group). We're on Vantage 8.03.406 and SQL Server.
> > > Â
> > > BACKGROUND:
> > > UD03Â will store information on each category such as
> > Description, and whether the category is active or not.  The PartThere
> and
> > UD03 tables will be joined on Part.ShortChar01= UD03.Key1. Â
> willthe
> > be a one-to-many relationship between UD03 and Part, meaning each
> > part will belong to one category but each category can be
> associated
> > with many parts.
> > > Â
> > > So far I've created 1) a UD03 Maintenance screen that allows
> > user to create/edit/ delete categories; and 2) a customization toto prevent
> Part
> > Maintenance that allows the user to select an existing UD03
> category
> > from a dropdown and assign it to the current part.
> > > Â
> > > PROBLEM:
> > > User can delete a category in the UD03 Maintenance screen even
> > if that category is being referenced by a Part.  One way
> > UD03 rows from being deleted would be to create a foreign keyVantage database?
> > constraint.Â
> > > Â
> > > QUESTIONS:
> > > Has anyone added a foreign key constraint in the
> > > Are there any gotchas that I should be aware of?
> > > Does this affect the Vantage support agreement?   Â
> > > Â
> > > TIA,
> > > Â
> > > Ahmet Erispaha
> > > Â
