I was told that if you sort a dashboard by a column and then try to select a record, right-click, select copy selected with headers, and paste into excel, it pastes the wrong result.
I have tested in 2 different dashboards and 2 different profiles.
It has been consistent.
For context, I used the taming the dashbaord dragon template to create them.
I tried out a couple of system dashboards and they copy fine after a column sort.
I have custom BAQs shown on my home page. I can copy paste from them after sorting and the columns are ok.
I also tried a deployed application from a BAQ. That grid also sorted and copy/pasted fine.
I did not use the taming dashboards process. I think I just followed the wizards.
On live version 2026.100.14
EDIT: I tried another more complicated application with a grid, and if the grid has grouping applied, the copy does not honor the grouping. But it still honored the sorting as if the grouping wasn’t applied.
Yes, the issue opnly came up on my own dashboard. I still haven’t gone through taming the dragons yet. So I just followed the wizard, and this forum. The issue did not appear on grids showing on my homepage, just on custom apps.
