On Click button Import the data in Kinetic Epicor App studio
Required code import button in Kinetic Application
@aosemwengie1
@dcamlin
@GabeFranco
Epicor Classic Code is given below, required kinetic code
private void btnImport_Click(object sender, System.EventArgs args)
		GetMiscShipDtls();
	private void GetMiscShipDtls()
	    try
	        EpiDataView edvMscShpHd = (EpiDataView)this.oTrans.EpiDataViews["MscShpHd"];
	        if (edvMscShpHd.Row < 0)
	            return;
	        string JobNum = edvMscShpHd.dataView[0]["JobNum"].ToString();
	        if (JobNum.Length == 0)
	            MessageBox.Show("Job Num Field is Empty.", "Warning");
	            return;
	        MiscShipAdapter adapterMiscShip = new MiscShipAdapter(this.oTrans);
	        adapterMiscShip.BOConnect();
	        int packNum = (int)edvMscShpHd.dataView[edvMscShpHd.Row]["PackNum"];
	        DataTable dt = GetJobMtlViaBAQ(JobNum);
	        bool hasVal = false;
	        if (dt == null)
	            return;
	        if (dt.Rows.Count > 0)
	            int i = 1;
				foreach (DataRow dr in dt.Rows)
	                int ShipQty = (int)(dr["Calculated_ShipQty"]);
					int MtlSeq = (int)(dr["JobMtl_MtlSeq"]);
					int ReqdQty = (int)(dr["Calculated_RequiredQty"]);
					int IssuedQty = (int)(dr["Calculated_IssuedQty"]);
	                if (ShipQty > 0)
	                    if (adapterMiscShip.GetByID(packNum))
	                        if (adapterMiscShip.GetNewMscShpDt(packNum))
	                            if (adapterMiscShip.OnChangePartNum())
	                                DataRow dRow = adapterMiscShip.MiscShipData.MscShpDt[adapterMiscShip.MiscShipData.MscShpDt.Rows.Count - 1];
	                                dRow["Company"] = dr["JobMtl_Company"].ToString();
									dRow["IUM"] = dr["JobMtl_IUM"].ToString();
	                                dRow["PackNum"] = packNum;
	                                dRow["PackLine"] = i;
	                                dRow["LineType"] = "PART";
									dRow["IssuedQty_c"] = IssuedQty;
									dRow["RequiredQty_c"] = ReqdQty;
									dRow["MtlSeq_c"] = MtlSeq;
									dRow["MiscShipDate_c"] = DateTime.Now.Date;
	                                dRow["HasShipped_c"] = true;
	                                dRow["Quantity"] = ShipQty;
	                                dRow["PartNum"] = dr["JobMtl_PartNum"].ToString();
									dRow["MtlSeq"] = (int)dr["JobMtl_MtlSeq"];
	                                dRow["LineDesc"] = dr["JobMtl_Description"].ToString();
	                                dRow["SysRowID"] = "00000000-0000-0000-0000-000000000000";
	                                dRow["RowMod"] = "A";
	                                adapterMiscShip.Update();
	                                i++;
	                                hasVal = true;
	            if (hasVal){
	                // SetExtendedProperties();
					this.oTrans.Refresh();
	                MessageBox.Show("Job imported successfully! ", "Success");
	            else
	                MessageBox.Show("This Job# "+JobNum+" was already shipped.", "Warning");
	               return;
	        else
	            MessageBox.Show("Job data was not found.", "Information");
	    catch (System.Exception ex)
	        ExceptionBox.Show(ex);
	private DataTable GetJobMtlViaBAQ(string JobNum)
	    DynamicQueryAdapter dqa = new DynamicQueryAdapter(oTrans);
	    dqa.BOConnect();
	    QueryExecutionDataSet qeds = dqa.GetQueryExecutionParametersByID("Get-JobDetailsForMisShipDtl");
	    qeds.ExecutionParameter.Clear();
	    qeds.ExecutionParameter.AddExecutionParameterRow("JobNum",JobNum,"nvarchar",false,Guid.NewGuid(),"A");
	    dqa.ExecuteByID("Get-JobDetailsForMisShipDtl", qeds);
	    if (dqa.QueryResults.Tables["Results"].Rows.Count > 0)
	        DataTable dtV = dqa.QueryResults.Tables[0];
	        return dtV;
	    else
	        return null;
Use a function don’t try to do code on the Kinetic layer.
@Randy is correct, you will want to convert that to sever side code and make function, which you will then call with an application studio widget. You should be able to find good resources on each of those steps on this site.
If you get stuck at a particular step, post details on the specific issue you are facing and what you have tried. The better you cover the business case and what you have tried, the more likely you are to get help. There is a decent post out there on writing a good post:
Try to remember everyone here has other work and responsibilities to attend to, we aren’t AI agents :grin:
If you need someone to do the project from start to finish, you should look for a consultant.
Done function working in kinetic… :smiley:
signature:
JobNum
PackNum
DataTable dt = null;
    //STEP 1: Execute BAQ and load data
    CallService<Ice.Contracts.DynamicQuerySvcContract>(dq =>
        Ice.Tablesets.QueryExecutionTableset qets = dq.GetQueryExecutionParametersByID("Get-JobDetailsForMisShipDtl");
        var qParam = qets.ExecutionParameter.FirstOrDefault(x => x.ParameterID.Equals("JobNum", StringComparison.OrdinalIgnoreCase));
        if (qParam != null)
            qParam.ParameterValue = JobNum;   // Set the parameter value
            qParam.RowMod = "U";              // Mark as updated
        DataSet  ds = dq.ExecuteByID("Get-JobDetailsForMisShipDtl", qets);
        if (ds == null || ds.Tables.Count == 0 || ds.Tables[0].Rows.Count == 0)
          result = $"No data found for JobNum: {JobNum}";
          return;
        dt = ds.Tables[0];
        if (dt.Rows.Count == 0)
          return;
       /* if (ds != null && ds.Tables.Count > 0 && ds.Tables[0].Rows.Count > 0)
            // Example: return the JobMtl_PartNum of the first row
            result = ds.Tables[0].Rows[0]["JobMtl_PartNum"].ToString();
        else
  //STEP 2: Create Misc Shipment Lines
  CallService<Erp.Contracts.MiscShipSvcContract>(miscShipSvc =>
    // STEP 1: Create Misc Shipment Lines Object
    Erp.Tablesets.MiscShipTableset ts = miscShipSvc.GetByID(PackNum);
    if (ts == null)
        result = $"PackNum {PackNum} not found.";
        return;
    int packLine = ts.MscShpDt.Count > 0
                   ? ts.MscShpDt.Max(x => x.PackLine) + 1
                   : 1;
    // STEP 2: Loop BAQ Results
        int shipQty   = Convert.ToInt32(dr["Calculated_ShipQty"]);
        int mtlSeq    = Convert.ToInt32(dr["JobMtl_MtlSeq"]);
        int reqdQty   = Convert.ToInt32(dr["Calculated_RequiredQty"]);
        int issuedQty = Convert.ToInt32(dr["Calculated_IssuedQty"]);
        if (shipQty <= 0)
            continue;
        // STEP 3: Create New Detail Line
        miscShipSvc.GetNewMscShpDt(ref ts, PackNum);
        var row = ts.MscShpDt.FirstOrDefault(r => r.RowMod == "A");
        if (row == null)
            continue;
        // STEP 4: Populate Required Fields
        row.Company  = dr["JobMtl_Company"].ToString();
        row.PackNum  = PackNum;
        row.PackLine = packLine;
        row.LineType = "PART";
        row.PartNum  = dr["JobMtl_PartNum"].ToString();
        row.LineDesc = dr["JobMtl_Description"].ToString();
        row.IUM      = dr["JobMtl_IUM"].ToString();
        row.Quantity = shipQty;
        row.MtlSeq   = mtlSeq;
        // STEP 5: Custom Fields
        row["IssuedQty_c"]   = issuedQty;
        row["RequiredQty_c"] = reqdQty;
        row["MtlSeq_c"]      = mtlSeq;
        row["MiscShipDate_c"] = DateTime.Today;
        row["HasShipped_c"]  = true;
        row.RowMod = "A";
        // STEP 6: Update
        miscShipSvc.Update(ref ts);
        packLine++;
        hasVal = true;
  // STEP 3: Single Update Call
  if (hasVal)
    result = $"Job# {JobNum} imported successfully!";
  else
    result = $"Job# {JobNum} was already shipped.!";
Glad you had success :slightly_smiling_face:
