On the fly part weights
Hi,
Is it possible to assign weights to on-the-fly parts? We need them for our intrastat reporting, but without a part record, there is no table to store this information in.
Any advice would be great, thanks.
I think you can enter them in the invoice entry screen - go to line detail and there should be an intratstat button enabled if the customer is setup this way - if customer is not setup this way I think the box will be greyed out.
We added a custom field to OrderDtl to hold the part weight. By default pulls in the Net Weight for a part in the Part table with BPM, but changeable for Part on the Fly.
Thanks guys, I’ve got some unused custom fields on Order.Dtl already so I’ll get the configurator to write to one of those. Is it easy to get that field into the intrastat report?
Cheers
Don’t have experience with the Instrastat Report. Did have to modify all our shipping and inventory reports, however. Anything to do with weights was non-existent to begin with. Since one of our KPIs is related to Tons Produced and Tons Shipped, a lot of customization was involved.
Cheers for the info, it sounds like we’ll have our work cut out then!
If you put the weight on the invoice it will appear on the intrastat report as is - only thing I am not 100% on is whether an on the fly part invoice will have the intrastat field available
