I am working on an event that has a couple of condition statements. I have never had an issue with placing as many widgets as I needed on a conditions true/false path. Now I am needing to add a second condition after a previous true statement. For some reason I can add all the widgets I want to the second condition but after I save they are gone except for one. This also happened with a switch widget. Am I missing something? Has anyone else had this issue?
Theorizing here… maybe it’s removing them because you did not fill those widgets out with any info? Try setting some messages in those and see if it sticks?
Just tried it the way you showed yours and mine works. What version are you on?
Got another question. When you replicated my problem did you branch off the true/false or did you drag the widget on the screen and then connect them? The reason why I ask is because I thought It was working for me until I realized I had just connected the condition with the erp-message-handler manually.
Still have not figured out what’s going on but in the mean time sense I can only have one item after the 2nd condition I can create another event with however many widgets I need and use event-next after the condition.
